CompletedLED CLOCK RESIZED 2 - DOTS PCB [40x66mm]
STDLED CLOCK RESIZED 2 - DOTS PCB [40x66mm]
350
:CC BY-SA 4.0
Creation time:2023-03-05 13:34:23Update time:2025-01-21 01:09:19
Dots PCB used in "LedClock- Resized 2 -40x66mm " project.
For some reason some online PCB preview tools will not generate Bottom Solder Mask Layer, so be sure to ask manufacturer to add it as in the picture below.
The PCB should be done with WHITE SOLDER MASK so the LEDs will reflect light better.
Also, in order to keep a clean look, please ask JLCPCB to place the Product No. on the location of JLCJLCJLCJLC text.
You will need one of this PCB with DOTS, 4 of these PCBs (https://oshwlab.com/mariusmym/7seg_40x66) and the Controller Board ( https://oshwlab.com/noobsmakingstuff/ledclock_controlboard) to complete this project.
More information here: https://github.com/mariusmym/LedClock-Resized
Software related stuff can be found in the @imeszaros gitHub repository, here : https://github.com/imeszaros/ledclock/blob/main/ledclock/users-guide.md
Installer provided also by @imeszaros can be found here : https://imeszaros.github.io/ledclock/
You have to use an FTDI / UART adapter for the initial flash of the Controler Board, or you can build yourself this fancy CH340C adapter: https://oshwlab.com/mariusmym/ch340c_auto-reset
STL files can be found here : https://www.printables.com/model/1087560-led-clock-all-in-one-pcb-powered-by-wled
CloneAdd to Album
