CompletedLED CLOCK RESIZED 2 - 7 SEGMENT PCB [40x66mm]
STDLED CLOCK RESIZED 2 - 7 SEGMENT PCB [40x66mm]
619
:CC BY-SA 4.0
Creation time:2023-03-05 11:30:24Update time:2025-01-20 02:36:39
7 Segment PCB used in "LedClock- Resized 2 -40x66mm " project.
For some reason some online PCB preview tools will not generate Bottom Solder Mask Layer, so be sure to ask manufacturer to add it as in the picture below.
The PCB should be done with WHITE SOLDER MASK so the LEDs will reflect light better.
Also, in order to keep a clean look, please ask JLCPCB to place the Product No. on the location of JLCJLCJLCJLC text.
You will need 4 of these PCBs, one PCB with DOTS (https://oshwlab.com/mariusmym/7seg_dots_40x66), and the Controller Board ( https://oshwlab.com/noobsmakingstuff/ledclock_controlboard) to complete this project.
More information here: https://github.com/mariusmym/LedClock-Resized
Software related stuff can be found in the @imeszaros gitHub repository, here : https://github.com/imeszaros/ledclock/blob/main/ledclock/users-guide.md
Installer provided also by @imeszaros can be found here : https://imeszaros.github.io/ledclock/
You have to use an FTDI / UART adapter for the initial flash, or you can build yourself this fancy CH340C adapter: https://oshwlab.com/mariusmym/ch340c_auto-reset
STL files can be found here : https://www.printables.com/model/1087560-led-clock-all-in-one-pcb-powered-by-wled
CloneAdd to Album
