Vibrino Uno MiniMax
STDVibrino Uno MiniMax
Vibrino Uno MiniMax is an Arduino compatible, breadboard-able, development circuit board with many extras not available on other circuit boards.
Based around the ATmega328 microprocessor.
The product photo is a previous working version I created that was aimed at Ghost Hunting and Paranormal Investigations. It was designed to read Temperature, Humidity, Barometric Pressure and EMF Fluctuations. This new version adds many additional functions. Add what you need, omit what you do not need.
Access is provided to all pins of the microprocessor. It includes ICSP to burn the UNO Bootloader. FTDI pins are available, or use the uUSB to upload sketches. Two i2C connectors for adding displays or other modules. uSD Card connector (optional) for datalogging. Real-time Clock circuit (RTC) optional.
One this unverified version, I added uUSB via the CH340E IC and an optional EEPROM.
I have included the working Arduino sketch I used for the first version of the Vibrino Uno MiniMax.
