Soft Touch Footswitch
STDSoft Touch Footswitch
Mode:Schematic/Simulation
Creation time:2024-05-30 13:25:29Update time:2024-05-30 13:43:21
This "Soft-Touch Footswitch" uses the MC14007 dual complimentary pair inverter to activate two JFet Transistors that switch between the effects intput or bypass signal. A silicone transistor activates the Power Indicator LED.
Be warned, this is laid-out using very small surface-mount components to keep the circuit board small enough! 0603's!
It uses a pcb-mount momentary Footswitch #SSWFS-S01-AA09-HWH , but it can use other momentary switches and a connector is provided for this.
The photo below shows a similar, but different type of footswitch that can be wired to work, as there is no 3D model of the one I recommend!
Circuit is unverified.
BOM_Soft-Touch-Footswitch_2024-05-30.csv
BOM_Soft-Touch-Footswitch_2024-05-30.pdf
1
Gerber_PCB_Soft-Touch-Footswitch_2024-05-30.zip
1
Schematic_Soft-Touch-Footswitch_2024-05-30.pdf
