Noise Gate
STDNoise Gate
Mode:Schematic/Simulation
Creation time:2024-05-26 15:03:00Update time:2024-05-26 15:21:13
Noise Gate is a simple circuit that I have used in another project, so I know it works, but this is a new, smaller design using surface-mount components and is currently unverified.
It can be added to an existing circuit or footpedal or made into a stand-alone stompbox.
It is about the size of a potentiometer-
VR1 is adjusted until the unwanted noise from a noisy circuit is shunt to ground by mosfet Q1.
When notes are played, the audio is amplified by Q3, which is then converted into a DC voltage by diodes D1 & D2 and applied to the base of Q2, which in turn, shunts the gate voltage on Q1 to ground- turning OFF Q1 and allowing the music/audio to flow freely.
Increasing VR1 potentiometer can also create a "gating-effect" which in some circumstances, is a desired effect.
BOM_Noise-Gate_2024-05-25.csv
11
BOM_Noise-Gate_2024-05-25.pdf
13
Gerber_PCB_Noise-Gate_2024-05-25.zip
9
Schematic_Noise-Gate_2024-05-25.pdf
16
11
