Insanity Boost Overdrive
STDInsanity Boost Overdrive
514
Mode:Schematic/Simulation
Creation time:2024-02-08 14:43:41Update time:2024-02-08 15:04:46
Insanity Boost Overdrive is a unique guitar foot pedal effect.
It samples the audio output, converts it to a +/- voltage, amplifies it, then sends it back to the positive and negative power inputs of the Opamp- boosting the audio signal headroom!
It is design to use my Footpedal and BuckBoost modules, that are also available here.
Diodes D1 & D2 protect the BuckBoost module from damage of voltages feeding back to the module.
the "Boost" potentiometer determines the overall voltage feedback to the opamp and clipping.
Separate, low noise, single circuit opamps are used to avoid any hysteresis.
