Guitar Jack Assembly
STDGuitar Jack Assembly
Mode:Schematic/Simulation
Creation time:2024-05-23 13:03:58Update time:2024-05-23 13:19:05
This is a Guitar Jack Assembly that will fit into a standard 125B Foot Pedal Enclosure (and larger sizes).
It uses a Switchcraft Mono 1/4inch Jack #SN37A12A for the guitar input and output and a pcb-mount 2.1mm X 5.5mm DC Input Jack (center negative!)
A connector for a +9v battery in also provided.
This module is to simplify the building of Guitar Effects Stompboxes/FootPedlas- only four wire connections need to be made to the effects circuit: +VCC, Ground, Audio Output TO FX, Audio Input FROM FX.
125B
SN37A12A_Data Sheet.pdf
Schematic_SugarFoot-Jack-Assembly_2024-05-23.pdf
BOM_SugarFoot-Jack-Assembly_2024-05-23.csv
Gerber_SugarFoot-Jack-Assembly_2024-05-23.zip
