OngoingOnStep SHC ESP32 PCB No Joy through holes
STDOnStep SHC ESP32 PCB No Joy through holes
OnStep SHC through holes version modified from Chad Gray's design
https://oshwlab.com/rchadgray/onstep-shc-esp32-no-joy
The ESP32 MCU is on the bottom so the OLED is on the same height as the buttons. 5mm nylon stand off super glued work fine to hold it up. The 100uF capacitor also on the bottom. The center joystick has been replaced by Chad with a button and it work fine.
The schematic remain unchange which direct cloned from Chad Gray's design. The axial resistors could be 2.2 KOhms or higher. The testing unit (as shown in the picture) use 2.4 KOhms.
The BOM section is copy from Chad Gray's design. Please open the PCB in Editor to view the BOM respectively.
Although this design working fine to me but it might not work for you. Please examine the PCB carefully.
