Vespa - Advanced Line-Follower Robot
PROVespa - Advanced Line-Follower Robot
Reproduction cost: $80
CERN Open Hardware License
Creation time:2023-06-12 19:34:24Update time:2025-03-12 08:36:24
Vespa: High-Performance Line-Following Robot
The Vespa is an advanced, high-speed line-following robot developed for competitive robotics. Designed with a focus on efficiency, precision, and modularity, the robot incorporates cutting-edge hardware and software to achieve superior performance in line-following competitions.
At its core, the Vespa features a custom-designed PCB that integrates the control system, sensor array, and motor drivers into a compact yet powerful platform. The main processing unit is a high-performance microcontroller optimized for real-time processing, enabling rapid adjustments and precise control over motor movements.
Hardware Overview
The Vespa is equipped with a state-of-the-art reflective sensor array, allowing it to detect and respond to line patterns with exceptional accuracy. This array consists of multiple high-speed infrared sensors that continuously scan the surface and feed data into the control system. The optimized signal processing algorithms ensure smooth and reliable trajectory tracking, even on complex curves and intersections.
Main PCB
To achieve superior speed and maneuverability, the Vespa utilizes high-power, low-inertia motors with precision encoders. The motor driver system ensures fine-grained control of acceleration and deceleration, maintaining stability at high speeds. The lightweight chassis, designed with an optimized center of gravity, allows for agile movement and minimal drift.
Software and Control
The Vespa employs a PID-based control algorithm, which continuously adjusts motor power based on real-time sensor data. Advanced filtering techniques are implemented to reduce noise and improve response times. The control system is fully programmable, allowing for fine-tuned parameter adjustments to suit different competition environments.
Modularity
Designed for ease of customization, the Vespa supports modular upgrades such as additional sensorsThis flexibility ensures adaptability for future competition challenges and evolving performance standards.
