L289N_MINI-FWF
STDL289N_MINI-FWF
Reproduction cost: $10
Creation time:2025-04-17 17:42:57Update time:2025-04-22 01:16:11
This PCB is designed to serve as a dedicated shield for the L298N MINI dual H-Bridge motor driver. It features a JST-XH connector for easy input connections and includes built-in indicator LEDs that display motor activity, regardless of direction, thanks to an OR-gate diode bridge configuration. An additional LED indicates when the L298N is powered and functioning. These visual indicators simplify debugging and ensure smooth monitoring during operation. The board is compact, efficient, and tailored for straightforward integration into robotics and motor control projects.
PCB Size: 40mmx40mm
Hole Rectangle: 30mmx30mm
Corner Radius: 5mm
Designed by Itamar Hoter Ishai, Yoav Aharoni, Noam Ron, and Tomer Ozer. - Team FWF
