HW-870 TCRT5000 IR Infrared Sensor
PROHW-870 TCRT5000 IR Infrared Sensor
Creation time:2025-12-20 00:55:09Update time:2025-12-22 01:27:37
Overview
The HW-870 is a high-precision infrared reflective sensor module based on the TCRT5000 optical sensor. It features an IR emitting diode and a phototransistor, making it an ideal solution for distance sensing and object detection in DIY electronics projects.
Key Features
  • Operating Principle: It works by emitting infrared light and detecting the reflected signal. The output signal changes based on the reflectivity of the surface (e.g., distinguishing between black and white lines).
  • Dual Output: Equipped with both Digital (DO) and Analog (AO) outputs. The digital output threshold can be easily adjusted using the onboard potentiometer.
  • Stable Performance: Built with a comparator (LM393) to ensure clean signals and strong driving capability.
Applications
  • Line-following robots (Path tracking)
  • Rotary encoders (Speed detection)
  • Paper detection in printers or fax machines
  • Non-contact limit switches
