ATtiny10 / DS18B20 Fan Controller
STDATtiny10 / DS18B20 Fan Controller
Features
Intelligent 2- 3- 4-wire Fan Controller based on ATtiny10.
- Uses DS18B20 digital temperature sensor.
- Automatically detects the presence of PWM control (4th fan wire).
- Operates in On/Off or PWM mode.
- Step-down DC-DC converter for fan power supply (up to 18 V at the input).
- 25 kHz PWM.
- Rotation control with an attempt to restart in case of rotor stop.
The controller regulates the fan speed using PWM, and the full PWM range (0 - 100%) fits into the temperature range of 25°C - 40°C. In the case of connecting a fan without PWM control or without a speed sensor (2- 3-wire fans), the control is carried out for a temperature threshold of 30°C: if sensor's temperature below this limit, then a logical 0 is set at the 6th pin of the chip, and if higher, then 1. This pin is used to control the EN pin of the DC-DC converter.
The module was designed to improve the cooling efficiency of various household and professional equipment.
See the detailed review of the project on my YT-channel (English subtitles): https://youtu.be/6zM7jxHXjjU
Details
To power the module, two sources will be required: 5V and Vfan = 4-18V.
For MCU Flash ROM programming you will need a USBasp programmer (or any other that supports the TPI - Tiny Programming Interface), which is connected according to this schematic:
The programming itself is performed from the Arduino IDE, with the ATtiny10 core installed in it (see the links below).
Please note that by default, the 6th pin of the microcontroller is used for the RESET signal (active level is low). To use this pin as a GPIO pin, you must rewrite the microcontroller's fuses (see the commands below). After you do this, you will no longer be able to flash the chip with a regular programmer. To program such a chip, you'll need 12V to be applied to the RESET pin.
Also note that the code is written for the MCU clock frequency of 10 MHz. This means that in the Arduino IDE, in the Tools->Clock menu, you should set the value to 8MHz, and then preferably calibrate the value of the OSCCAL register in the code for your specific exemplar of the chip. This can be done, for example, by measuring the duration of the 1-wire reset pulse using an oscilloscope. Its duration should be as close as possible to 480 microseconds.
Links
Code - https://github.com/DmitryMuravyev/ATtiny10-DS18B20-Fan-Controller
Datasheet ATtiny4-5-9-10 - http://ww1.microchip.com/downloads/en/DeviceDoc/atmel-8127-avr-8-bit-microcontroller-attiny4-attiny5-attiny9-attiny10_datasheet.pdf
Tips and Tricks to Optimize Code for 8-bit AVR - https://ww1.microchip.com/downloads/en/AppNotes/doc8453.pdf
Datasheet DS18B20 - https://datasheets.maximintegrated.com/en/ds/DS18B20.pdf
1-Wire protocol (Book of iButton standards) - https://pdfserv.maximintegrated.com/en/an/AN937.pdf
USBasp firmware - https://www.fischl.de/usbasp/
USBasp firmware update guide - https://www.electronics-lab.com/project/usbasp-firmware-update-guide/
ATtiny10Core for Arduino IDE - https://github.com/technoblogy/attiny10core
Programming the ATtiny10 - http://www.technoblogy.com/show?1YQY
ATtiny10 Thermometer - http://www.technoblogy.com/show?2G8A
Commands
Fuse programming (0xFE - set RSTDISBL bit): avrdude -C ..\etc\avrdude.conf -c usbasp -P usb -b 115200 -p attiny10 -v -U fuse:w:0xFE:m
Fuse reset: avrdude -C ..\etc\avrdude.conf -c usbasp -P usb -b 115200 -p attiny10 -v -x section_config -e
Components
DS18B20 Temperature Sensor - https://ali.ski/Alu_j-
SMD Capacitor Sample Book - https://ali.ski/l-lE9
SMD Resistor Sample Book - https://ali.ski/6YxlCV
KF2510 3+1P Fan connector - https://ali.ski/kyrey
