CompletedDaisy seed power and opamps
STDDaisy seed power and opamps
:CC BY-NC-SA 3.0
Handy Breakout PCB for the Electrosmith Daisy Seed that can be very helpful for prototyping, especially when working with eurorack signals.
- DC DC converter from +/- 12 Volts eurorack power to +5 Volts for the daisy seed.
- Opamps for audio in and audio out, eurorack level.
When using long headers it can be plugged into a breadboard for fast prototyping while using the clean power and the op amps.
Bit fiddly to install on breadboard, but once in place worth the hassle.
To install on breadboard i use long female headers.
-> Daisy seed with normal male headers plugs in the female headers
-> female headers through PCB plug into breadboard.
All daisy pins are then available on the breadboard, audio in and out through opamps are available as well as +/- 12 Volts.
I have put up a small website with more pictures, links and code.
Also there you can find an Eight channel input protection and multiplexer board that scales Eurorack level -/+ 5 Volts to safe 0 – 3.3 Volts, these scaled signals can be used directly or via the multiplexer thats on board.
These 2 breakout boards helped me tremendously while developing DSP audio on the Daisy Seed and interfacing with eurorack.
The daisy seed breakout boards are an open source project.
The schematics and PCB designs are licenced as CC BY-NC-SA 3.0.
For the daisy seed power management and op amps i refered to:
kxmx blümchen and daisy patch by electrosmith
For input protection:
kxmx blümchen and Mutable instruments clouds
For multiplexing:
Takumi Ogata electrosmith tutorial
