RGB 565 - ESP32-S3 with Touch Display Controller
PRORGB 565 - ESP32-S3 with Touch Display Controller
Mode:OSHWLab Stars
OSHWLab Stars
Public Domain 公共领域
Creation time:2024-10-13 19:23:11Update time:2024-11-15 21:40:47
ESP32-S3 controller for 480 x 600 RGB interfaced display through ribbon cable with ILI6122 Driver embedded on cable. Includes a 6 pin touch interface using I2C. There is additionally a low side power switch mosfet and flyback diode for driving a small 100 - 200mA load from VBUS.
Supports external 5V input power and USB power with some basic shottky diodes as reverse protections to prevent backfeeding the sources.
USB programmable, along with one extra spare UART header for the second serial port.
LED diagnosis of input power.
Onboard backlight LED driver chip to boost from 4.5V nominal.
Most parts have been selected to be basic parts, unfortunately connectors are hard to find a basic part for.
DESIGNED FOR
DISPLAY MODULE PART NUMBER : NHD-5.0-800480TF-ATXL#-CTP
