Xiaozhi Moon round - screen AI chatbot with ambient light
PROXiaozhi Moon round - screen AI chatbot with ambient light
CC BY-NC 3.0
Creation time:2025-04-24 01:51:23Update time:2025-04-24 05:42:23
A cool round-screen Ash AI with ambient lighting
1. Introduction
This is a Xiaozhi AI chatbot equipped with a 1.28-inch round screen Equipped with 12 WS2812 magic light beads, voice control to switch a variety of lighting effects, switch lights, screen flip, and increase the standby clock function.
Note: Any commercial use is prohibited in this project, and the appearance patent has been applied, and personal DIY is not restricted.
Video demo link [Cool Xiaozhi with Ambient Lighting Artificial Intelligence - Bilibili] https://b23.tv/sNJNjXw
2. Circuit design description
Dimensions: 41.6x41x18.1mm
Circuit Configuration:
ESP32-S3R8 main control chip
16MB NOR FLASH
ES8311
NS4150B
ZTS6216 MEMS microphones
1.25 horn and battery socket
Note: The MX1.25 terminals on the board here are not soldered
3. Enclosure design and installation instructions
Case size: diameter 51.2mm thickness 15.5mm
Battery selection: 802025 lithium battery - 350mAh, MX1.25 positive terminal, purchase link https://item.taobao.com/item.htm?id=596564964361
Horn selection: 3012 cavity horn, MX1.25 positive terminal, purchase link https://item.taobao.com/item.htm?id=722575588114
Screw selection: M1.6*4 head diameter 3mm (note that you must buy a head diameter of 3mm) purchase link https://item.taobao.com/item.htm?id=649403948385
Installation Steps:
(1) Thread the screen cable from the front to the back through the reserved opening, and insert the FPC socket.
(2) Plug the battery and speaker into the main board of the circuit board, and fix the horn and the battery with double-sided tape (the protrusion inside the shell is the limit of the battery and the speaker, and it needs to be glued to the limit position)
(3) Align the screw holes of the motherboard with the screw holes of the shell, lay the screws first, and then paste the screen on the motherboard with double-sided tape.
(4) Put the button into the small part of the shell first, and insert the small part of the shell into the large part of the shell (note that the button and the small part of the shell are multiple splices, and the excess connection material needs to be cut off)
(5) Put the cover on the shell.
Designed by Anbin (from OSHWHub)
Link:https://oshwhub.com/anbin/xiao-zhi-moon
Installation step-by-step demo video .mp4
51
3D printed file .zip
56
Moon firmware .bin
83
Cover - Coloring .dwg
26
