CompletedRTL8812EU motherboard 38x38 openipc FPV
This project is designed to use a 38*38mm camera board with OpenIPC FPV system, the camera board uses Hi3516EV200+IMX307, the lens uses F2.8MM M12 lens, and other lenses may not be fitted.
It supports 2~4S direct power supply, or directly power supply with flight controller and provides mavlink data. After the module is assembled, only one terminal is needed to solve the problem of power supply and serial port data connection, and it can be directly fixed on the GoPro base.
DIY is risky, please be cautious when placing orders, the author is not responsible for all kinds of accidents and losses that may occur.
Bill of Materials
1- 8812EU Must Connect wifi module 1pcs
2- 3D printed 2pcs (one camera board, one wifi board, file accessories provided)
3-4mm copper post nuts 4pcs (assembled to the camera board 3D print, fixed motherboard use, used UV glue to fix the copper post and 3D print)
4- 8mm copper post 4pcs, need to come with 3mm screws
5- The fan adopts 5V with heat sink 25mm*25mm
6- PM2*8mm screws 4pcs
Notes:
You need to pay attention to the thickness of the plate 1.0mm (because the thickness of the shell is just right)
Assembled pictures
Designed by OpenDIY (from OSHWHub)
