Redmi 4 Direct Power Extension (klipper)
PRORedmi 4 Direct Power Extension (klipper)
Creation time:2024-12-10 03:12:46Update time:2024-12-10 03:44:44
Red light power, green light hub.
QQ图片20231217210008
The extended version can act as a back cover.
Reserve 4 m3 holes for easy mounting brackets.
QQ图片20231217210016
Divided into two plates, you know (≤10cm)
QQ图片20231217203642
The red arrow is the selection switch of flashing and hub,When you connect to the lower computer, you can dial it to the hub (at this time, the hollow will be lit),When you flash the machine, you will dial it to the flashing machine (even Xiaozheng K6 motherboard also needs to be dialed to the flashing machine,Because Xiaozheng k6 motherboard integrates hub,At this time, you only need to use a data cable to connect the extended version of the "Xiaozheng k6" USB-A and the typec port of the Xiaozheng k6 motherboard)
The components are tested internally, which is beautiful and can avoid static electricity or foreign body contact and short circuit.
QQ图片20231217203731
The components in the red box can not be pasted (so that there is no wide voltage input function, and only typec5v power supply) The green arrow is the contact point of the mobile phone.
QQ图片20231217203748QQ图片20231217203809
If a WiFi antenna is added to the cover, the signal will be improved compared to directly removing the back cover (the original antenna on the back cover).
No fancy circuits, multiple incense burners and multiple ghosts, everything is simple and convenient DIY. The circuit has been extensively verified (the one with the most sales of the direct power supply extended version of the Redmi 2 is this circuit)
If the schematic diagram is not drawn, the BOM list shall prevail below!!!!!!!!!
Serial number
Quantity
Model
Encapsulation
1
9
100nF
C0805
10
10uF
C0805
20pF
C0805
1
100p
C0805
1
OK-14030-04Female
LED-ARRAY-SMD_8P-L5.2-W5.0-TL-FD
https://m.tb.cn/h.5NT33XZ?tk=3wDOW5irtkQ
1
SS210
SMA_L4.3-W2.6-LS5.2-RD
1
SS34
DO-214AC_L5.0-W2.5-LS5.0-FD
1
4.7uH
IND-SMD_L7.0-W6.6_0630CDMCCDS
9
LED
LED0805-RD
Available in two colors
10
1
7-pin slide switch MSK-12C01-07
https://m.tb.cn/h.5nKWuuT?tk=ezK3W5iJU2s
11
1
3kΩ
R0805
12
100k
R0805
13
1
8.2k
R0805
14
1
44.2kΩ(63C Precision Resistor)
R0805
15
1
SL2.1A
SOP-16_L10.0-W3.9-P1.27-LS6.0-BL
16
1
MP1584EN
SOIC-8_L4.9-W3.9-P1.27-LS6.0-BL-EP3.3
17
USB-A
USB-A-TH_KH-AF180WJ-13.7-JB
18
1
Passive crystal oscillator 12MHz
3225
19
1
USB-TYPEC-14P
MICRO-USB-TH_MICRO-USB-A14
https://m.tb.cn/h.5NwYWN6?tk=0IWXW5istt9
20
Hot melt nut M3*3*4.2
21
10
Screw M1.4*5.5
QQ group: 759851283
No. 5 OK-14030-04 Female.
Key switch.
Typec-14p.
The board file (body) is .zip
58
The board file (antenna cover plate) is .zip
46
BOM.xlsx
41
