OpenIPC SSC338Q + 8731 + 5542 power amplifier AIO board
PROOpenIPC SSC338Q + 8731 + 5542 power amplifier AIO board
CC BY-NC-SA 4.0
Creation time:2025-11-03 08:48:13Update time:2025-11-05 12:16:27
Sorry, stupid, download the attachment before October 27 XDM Sorry, the soldering aid is sent the wrong version, the new one has been packaged and uploaded, in the compressed package
This design is only for tossing, learning, communicating techniques
Not recommended for use in production environments
The author will not be responsible for any losses caused as a result
DIY is risky, please be cautious when placing orders, the author is not responsible for all kinds of accidents and losses that may occur
Okay, without further ado, let's start introducing
I don't open source motherboards, camera PCB engineering files, only open source gerber, schematics, firmware, BOM uploaded PCB is useless, schematics, etc. are normal open source (the reason is plagiarism by foreign companies, so I won't name them)
The board supports 25.5 holes, but 25.5 holes, requires a shock absorbing column, and the size of the plate frame is only 27.5x27.5mm (one turn smaller than the snail 1s)
Then, I have verified that everything is functioning normally
The data port leads to ttys0, which supports data transmission between Ruby and FPV firmware
Use SSC338Q main control, 8731BU network card, 5542 amplifier
Camera IMX415, 14x14mm, M8 lens
600MW transmit power
Focus: The power supply uses 5V power supply, although there is a TVS, but it can only prevent you from connecting backwards, and the wrong voltage leads to burnout, I can only say: let you not watch, s*d
If you connect it wrong, 338Q will die directly
Please call JLC06161H-7268 (free/finished board thickness 1.60mm±10%)    Remember to check the  20%  impedance (don't be in vain)
338Q and 30KQ are pin to pin, which means that 338Q boards can also be used with 30KQ
My board is compatible with the side, Mingyue's camera, just remove the R83 resistor
The 3D printing shell gcode file is lost in the attachment, the stl file is lost (
PS: The fever is high, and the machine dies at 140 degrees in 5 minutes
The camera's two LDOs are packaged with these two or the same LDO with a voltage of +-0.1V
Designed by 不会取名 (from OSHWHub)
Link:https://oshwhub.com/wmdsz/openipcssc338q-8731-5542-amplifi
readme.txt
11
The 338+8731+5542 AIO board supports MSPOSD (with camera) .zip
16
