Isolated DAP-Link debugger based on AT32F415
PROIsolated DAP-Link debugger based on AT32F415
Creation time:2024-12-18 06:36:54Update time:2024-12-18 10:02:31
AT32F415-based isolated DAP-Link debugger
Changelog
20240522 First release
20240527 Updated firmware 20240527.hex to optimize the transceiver performance of the serial port
20240611 Update firmware 20240611.hex, optimize SWD speed, support dual serial port function, if you need to use the host computer, you can choose the old version of firmware
20240717 Updated 3D printed enclosure link
20241125 Update firmware 20241125.hex to fix the non-dual serial port issue of 20240611.hex
Key features
Based on the AT32F415 chip of Artery, an isolated DAPLink debugger is designed, which supports up to 1500V isolation (5KV can be reached without connecting to the isolated power supply), which can be used to debug other equipment such as motor control boards.
Using the CherryUSB framework, together with the optimized DAPLink code, it is possible to achieve high download speeds and 4M speed serial communication under USB FS.
Design Essentials
1. USB Type-C design, convenient for long-distance debugging.
2. The use of Chuanshi micro isolation chip to achieve full isolation of power supply and signal, to prevent high voltage from entering the computer circuit through the signal line.
3. 5V isolated power supply (solderless) is used to isolate the signal and equipment at the opposite end, with short circuit protection and other functions.
4. Use 3U gold-plated horn seat (optional) for a more exquisite appearance.
5. Keep the cost of materials low.
Software Features
1. DAP SWD download/debugging, the oscilloscope measured the maximum SWD frequency is about 8M.
2. USB to serial port, can achieve 4M baud rate without losing characters (can develop the second serial port to USB)
3. Support USB updater, no need to disassemble to refresh the program.
4. Support host computer, which can be used to configure DAP ID to easily distinguish multiple DAPs.
5. The serial number generated according to the unique code of the chip can prevent duplication.
Enclosure printing and assembly
File: upper.stl lower.stl
The slice file can be found in the attachment shell.3mf
For more information, please refer to: https://makerworld.com.cn/zh/models/335477#profileId-266989
After printing, use a soldering iron to melt four nuts into the hole, and then put the board into it, and then use M3*5 screws to screw it in from the class, the reference figure is as follows:
Screw purchase link (choose color classification: M3 * 5 (100 pcs)):
https://detail.tmall.com/item.htm?id=624811454452&spm=a1z09.2.0.0.1de82e8d8Zps2p&_u=h2dklb456894
Hot melt nut purchase link (color classification: M3*6*4.2 [100 pieces]):
https://detail.tmall.com/item.htm?id=598418504681&spm=a1z09.2.0.0.1de82e8d8Zps2p&_u=h2dklb458180
Original purchase link
1. 10P horn seat (Select color category: 10P Specification: straight needle):https://item.taobao.com/item.htm?_u=m2dklb45f734&id=712321967438&spm=a1z09.2.0.0.e8dd2e8dC6CepY
2. White plate Type-C seat (want to look good can buy this, normal reference BOM table can be purchased):https://item.szlcsc.com/3272613.html
3. Isolated power supply (choose B0505S-3WR2 [5V to 5V600mA], the original is also available in lcsc):https://detail.tmall.com/item.htm?_u=m2dklb45d901&id=612898477250&spm=a1z09.2.0.0.e8dd2e8dC6CepY
4. Isolation chip (CA-IS3742HW, CA-IS3741HW):https://item.taobao.com/item.htm?_u=m2dklb45ea32&id=609653319378&spm=a1z09.2.0.0.e8dd2e8dC6CepY
5. AT32F415CCU7:https://item.taobao.com/item.htm?_u=m2dklb45fe39&id=650419388165&spm=a1z09.2.0.0.e8dd2e8dC6CepY
6. ESD:https://item.taobao.com/item.htm?_u=m2dklb45580f&id=653799154764&spm=a1z09.2.0.0.6b752e8dC0aQg2
(Other originals can be purchased according to BOM)
The program is open source
Note that select one_uart branch, and the test firmware can refer to the attachment: 20240523.hex
https://gitee.com/fhcloud/at_-f415_-dap
Firmware flashing tutorial
Download ISP Tool:https://www.arterytek.com/file/download/1720
Hold down BOOT0 and connect the USB port of the debugger to the computer, and the computer should be able to hear the USB recognition.
Select the Artery_DFU_DriverInstall.exe in Artery_ISP_Programmer_V2.0.13\Artery_DFU_DriverInstall, double-click to install the USB DFU driver.
After the installation is complete, open the ArteryISPProgrammer.exe in Artery_ISP_Programmer_V2.0.13\Artery ISP Programmer_V2.0.13 and start burning.
Private protocols are open source
This debugger supports a private protocol to connect to the debugged chip, and the protocol refers to the attachment "Isolated DAP HID Communication Protocol", which can be controlled by using a host computer .7z
Display pictures
Designed by FanHuaCloud (from OSHWHub)
Link:https://oshwhub.com/fanhuacloud/dap-link-iso
Isolate DAP HID communication protocol .pdf
119
upper computer .7z
179
20240523.hex
42
20240527.hex
39
20240611.hex
36
Shell .3mf
12
upper shell.stl
11
Lower shell.stl
11
9
20241125.hex
