EMC / EMI Probe Low-noise Amplifier
PROEMC / EMI Probe Low-noise Amplifier
CC BY-NC-SA 4.0
Creation time:2024-09-25 03:02:01Update time:2024-09-25 09:58:35
Image_1721747142323
Introduction:
EMC/EMI electromagnetic radiation amplifier, used in electronic product detection electromagnetic radiation noise detection amplification, RF power amplifier pre-gain amplification, self-contained power supply, independent power supply for 3 hours of continuous battery life, external power supply. The input is connected to the probe, and the output signal can be directly fed into the spectrum analyzer or RF power amplifier.
Open source license: CC-BY-NC-SA-4.0
Parameter:
FREQUENCY RANGE: 0.05GHZ-4GHZ
Amplification gain: 20dB (two-stage amplification)
Impedance: 50Ω
Power supply: 5V-1A
Battery capacity: 250mAH (3 hours on a full charge)
IMG_20240709_112552
Probe: Impedance 50Ω
The RF part of the low noise amplifier chip uses: SPF-5189Z
Two-stage amplification, single-stage amplification 10dB, two-stage 20dB
IMG_20240723_225008
Vector network amplification gain test: -30dB gain attenuator is serial in the RF line, and the interface loss is calibrated, and the line loss is about 1.95dB
IMG_20240723_225055
Vector screen amplification gain test: low noise gain amplifier is inserted in series, and the total attenuation is 10.99dB=30dB-20dB
(Note: The charge pump and LNA chip will heat up during operation, and if heat dissipation is not performed, the charge pump will heat up and overheat the protection and reduce the LVA amplification gain)
The power supply part is powered by lithium battery, the charge pump is boosted to reduce the power supply noise, and the power supply charge pump is HX4002
(Note: The charge pump and LNA chip will heat up during operation, and if heat dissipation is not performed, the charge pump will heat up and overheat protection)
IMG_20240709_112552
IMG_20240709_112549
IMG_20240709_102820
The probe is a panel, and after proofing, it needs to be split and polished by itself: different probes are suitable for different detection areas.
The shell is a lightweight aluminum alloy shell, and the finished shell is selected for cost considerations, but there are gaps in the assembly of the shell, and it is recommended to choose the CNC machined shell in pursuit of low noise and avoiding external interference.
Image_1719647388367
c823328c74413868fa3545c2375f3f33
Image_1719647389646
A(X3]J_Y6_BCS}L365N6IG2
Processing parameters: CAD drawings, processing needs to send the drawings to the manufacturer
Front Panel:
96P7~M$$QYM`LL]@($]EU8K
Rear Panel:
TJGBJSFD25}M37BF``U}NAI
Remarks: (Laser marking is recommended for the font part)
PCB Assembly Effect:
IMG_20240728_193853
Heat sink installed on the heating part:
IMG_20240728_194218
Full Component Drawing:
IMG_20240728_194313
Diagram of the finished product:
IMG_20240728_195641
Simulation Diagram:
See attachment for shell CAD machining pictures and CNC machining files.
Test video: The interference source comes from the buzzer at the bottom of the MCU development board.
0.05~4GHZ 20dB gain, self-powered EMC/EMI low noise amplifier, used for EMC/EMI electromagnetic leakage front-end detection and amplification of electronic products. Equipped with self-made probes.
Link:https://oshwhub.com/dingcheng/emcemi-probe-low-noise-amplifier
Shell processing file.zip
35
VID_20240723_230453.mp4
21
