CompletedELRS_GEMINI High Frequency Headset
ELRS_GEMINI LNB
1. Operation Process
1. After PCB soldering is completed, first program the backpack ESP01F and then the ESP32;
2. There are two shorting pads (programming, communication) on the PCB, which are used for programming the esp01f. Shorting the "programming" label means programming (hold down the second boot key when powering on), and shorting the "communication" label means communicating with the esp32;
3. Power on without shorting any pads to program the esp32;
2. There are many programming methods, here are a few recommended:
Below, the ZIP package contains PCB, configuration files, firmware, tool utilities, shell STL, and so on.
Both JR and XT30 interfaces support 28V power supply.
The power supply is divided into two parts: 5V/3.3V
Designed by UFOIO (from OSHWHub)
Link:https://oshwhub.com/ufoio/elrsgemini-high-frequency-head
