Desktop heater
PRODesktop heater
Creation time:2025-03-20 08:40:01Update time:2025-03-21 01:28:29
Let's start with the appearance display.
Heater overall size 70 * 33 * 90 Unit: mm
Assembly tutorial
Because the 3D shell is relatively compact, there is almost no need for hardware to fix it after installation
The work this time is really full of ups and downs. At first, I saw that Li Chuang could produce and process electric heating films, so I thought of making a small electric heating thing. Considering that the electric heating film is a single film, if you want to make a heater, you need several electric heating films interwoven together, and you need a suitable heat sink. After finding it troublesome, I replaced it with a PTC heating element, and then a bigger trouble came........... The rated power of the PTC heating element purchased by the author is 50w, but I didn't take it seriously. I thought 12V2A was enough, and the PTC dry burning temperature was about 200 degrees. I didn't need such a high temperature, so I used a 12V2A power supply for debugging. As a result, the NND current couldn't be controlled, and it was directly short-circuited for protection...........
Yes, in order for current heaters to reach a temperature of about 15cm and reach 50 ℃, they must use a professional power supply or a 12V 5A constant current source... However, it doesn't seem appropriate to use such a small heater with such a large power supply. Therefore, it is recommended to choose a 5V fan when choosing a fan. Currently, the 5V PTC heating element can only be customized, and the 12V one can also be used, but the surface temperature is only about 40 ℃.
Below are the temperature of the PTC hot chip corresponding to different voltages.
12V5A - Surface temperature 130 ℃
Distance around 15cm - 51 ℃.
5V1.2A - Surface temperature 39 ℃, this temperature is barely felt by the wind (T^T)
Therefore, it is recommended that you choose a power supply for the hot plate not greater than 7V, otherwise the current will continue to rise, or replace an 8A short-term power adapter (T^T)
Notes
Do not block the trend
Choose the power supply small board for PCB board proofing
Designed by zzron (from OSHWHub)
Link:https://oshwhub.com/zzron/test
Support 2.step
37
Support 1.step
21
shell.step
20
Back cover.step
24
