32-bit 4-in-1 ESC Version 1.0
PRO32-bit 4-in-1 ESC Version 1.0
CC BY-SA 4.0
Creation time:2025-09-19 02:41:12Update time:2025-09-19 03:14:56
Introduction to ESC
  • The AM32 ESC uses a single-sided copper strip overcurrent (2×1mm square section copper strips can be used), so that the PCB can withstand large currents using the default free proofing settings;
  • This ESC uses NTMFS5C430NLT1G onsemi N-channel MOS tube, with a continuous drain current of up to 200A (40V 1.4mΩ);
  • The overall design layout is compact, with dimensions of 40.5mm×49.3mm;
  • BL flashing is recommended to use the Chuangxin workshop burner, and then brush the firmware through the flight control
  • Because the first time I sent open source, many people don't understand, if there is any infringement, you can contact to delete
  • The control board has 0201 resistor can be replaced with 0402, if it is replaced by caution not to be falsely soldered, where the resistance value in the step-down chip can be replaced with 160k and 10k instead of the original 110k and 9.1k output 10V voltage, which can reduce the MOS on-resistance. (I verified that there is no problem)
  • 6 layers of power floor, if you are prostituted for free, the next time you will be stuck on the 6th floor, you need to pay to play the 6th floor to unlock, here is a special statement (I will change this problem in the next version 2.0)
AM32 firmware .zip
20
