TXU0202 DIP Adapter
STDTXU0202 DIP Adapter
332
Creation time:2023-08-12 20:13:28Update time:2023-08-13 12:25:37
A simple DIP adapter for a TI TXU0202 voltage level translator. Well suited for UART level translation between two sides sharing the same ground but using different logic levels (1.1V to 5.5V).
The VSSOP-8 is small, so using hot air or a small soldering iron tip, and not too much solder, is recommended.
The two 0603 capacitors should be 100nF.
A 3D render of the board:
