OngoingLatching power switch strip micro USB
STDLatching power switch strip micro USB
USB-Controlled Load Switch with MOSFET
🔧 Project Purpose
This project implements a simple MOSFET-controlled switching system powered via a USB connector. It allows the user to manually control the power delivery to a load (such as an LED or other small device). The circuit includes an indicator LED showing the load status and incorporates protection and filtering components for safe and stable operation.
🔌 Key Features and Components
1. USB Power Input and Filtering
Connector: USB (labeled as INPUT)
Fuse (F1, 0466003.NRHF): Protects the circuit against overcurrent conditions.
R5 (200 Ω): Series resistor on the D+ line, possibly for identification or protection.
L1 (80 Ω): Small inductor for power line noise filtering.
C1 (100 µF): Bulk capacitor to filter voltage fluctuations on the VCC rail.
2. Control Switch
SWITCH (XKB5858-Z-E-75): Manual pushbutton used to control the MOSFET gate.
D1 (1N4148WS): Diode for protecting the gate circuit from voltage spikes.
R3, R4, R22: Resistors forming voltage dividers and pull-down configurations:
R3: 100 Ω in series with the gate
R4: 1 MΩ pull-down resistor
R22: 100 kΩ for gate voltage control
3. Load Switching via MOSFET
Q2 (AOD4184A): N-channel MOSFET acting as a switch for the load.
LOAD connector: Allows connecting an external load device.
C2 (10 µF): Decoupling capacitor for the load.
OUT LED + R1 (1 kΩ): Visual indicator (green LED) showing when the load is active (MOSFET is conducting).
⚙️ How It Works
Power Supply: USB provides voltage to the system.
Protection and Filtering: Fuse, inductor, and capacitor ensure clean and safe power delivery.
Switch Control: User presses the pushbutton switch to alter the MOSFET gate voltage.
MOSFET Operation: When the gate receives sufficient voltage, the MOSFET turns on, connecting the load to ground and allowing current to flow.
Status Indicator: The green LED lights up to indicate the load is powered.
🔐 Protection and Safety Features
Fuse: Guards against overcurrent damage.
Diode: Protects the MOSFET’s gate from voltage transients.
Inductor & Capacitors: Filter out power supply noise and stabilize the system.
Pull-down Resistors: Prevent the MOSFET gate from floating and turning on unintentionally.
✅ Possible Applications
Simple USB-powered load controller
Manual switch for LEDs or small DC devices
Projects needing load control without microcontrollers
Educational circuits for learning about MOSFETs and power switching
