LM386 Amplifier v2.1
STDLM386 Amplifier v2.1
Creation time:2024-11-01 13:13:49Update time:2024-11-02 06:25:40
LM386 Loudspeaker Amplifier
Supply voltage: 12V
Audio channel can be selected with the selector switch because this amplifier is mono audio amplification only!
PCB has volume slide, 10k potentiometer
Amplified voltage can be taken from the Terminal Block or from the Molex Connector, pay attention in the polarity!
Circuitry can be modified easily if different gains is needed or different speaker impedance is needed.
In this configuration the gain is around 50 and works with 8ohm to 16ohm speakers.
REVISION: 2.1
Check out my older REV1.0 project with this chip:
https://oshwlab.com/markus_jidoka/lm386
