ESP12-F Grove Sensor Development Board
STDESP12-F Grove Sensor Development Board
Creation time:2025-10-17 13:15:12Update time:2025-10-20 01:37:39
Overview
This project is a development board based on the ESP-12F (ESP8266MOD) microcontroller module, designed for use with the Grove - Sound Sensor.
The board accepts a 5 V power input via a Micro USB connector, protected by a fuse and Schottky diode. The voltage is regulated down to 3.3 V using an LD1117V33 LDO regulator, supplying power to the ESP module and peripheral components.
The main purpose of this project is to provide a compact, programmable platform for sound-based applications — such as sound detection, voice-triggered control, or noise level monitoring.
Power Supply and Protection
  • Power Input: Micro USB connector (X1) provides 5 V DC to the board.
  • Fuse (F1): 750 mA polyfuse for overcurrent protection.
  • Diode (D1, 1N5819 Schottky): Prevents reverse current flow and protects the USB source.
  • Voltage Regulator (U2, LD1117V33): Converts 5 V input to a stable 3.3 V output for the ESP-12F and related circuitry.
  • Capacitors (C1–C6): Used for filtering and voltage stabilization (values from 100 nF to 100 µF).
Main Components
1. ESP-12F (ESP8266MOD)
  • Serves as the main microcontroller and Wi-Fi interface.
  • Connected to an external FTDI programming header (J1) for USB-to-UART communication.
  • GPIO pins (e.g., GPIO0, GPIO2, GPIO15) are configured for boot mode selection and normal operation.
  • RESET and FLASH push buttons are provided for programming and system reset.
2. Grove - Sound Sensor
  • Connected via a dedicated 4-pin Grove connector (PH-4A type).
  • Signal output is fed into the ESP’s ADC input through a voltage divider (R12 = 2 kΩ, R13 = 1 kΩ).
  • Allows measurement of sound amplitude as an analog voltage.
Programming and Operation
  • FTDI Header (J1): Enables easy programming and serial communication with the ESP module.
    • Pins: TXO, RXI, DTR, CTS, VCC, GND.
    • The DTR signal is routed to EN and GPIO0 to support automatic bootloader mode for flashing firmware.
  • Buttons:
    • FLASH – Forces the ESP into programming mode when held during reset.
    • RESET (RST_USER) – Resets the microcontroller.
Technical Specifications
Category Description
Input Voltage 5 V DC (from USB)
Regulated Voltage 3.3 V via LD1117V33
Protection 750 mA fuse + 1N5819 Schottky diode
Microcontroller ESP-12F (ESP8266MOD)
Sensor Grove - Sound Sensor
Programming Interface FTDI header (supports auto-flash via DTR/EN/GPIO0)
User Controls FLASH and RESET push buttons
Indicator Red LED
Designer Markus Virtanen
Company Etteplan Finland Oy
Date October 17, 2025
Revision 1.0
Gerber_ESP12-F-Grove-Sensor-Development-Board_2025-10-19.zip
BOM_ESP12-F-Grove-Sensor-Development-Board_2025-10-19.csv
PickAndPlace_PCB_ESP12-F-Grove-Sensor-Development-Board_2025-10-19.csv
