3s_Li-Ion_Voltage_Indicator_v1
STD3s_Li-Ion_Voltage_Indicator_v1
Creation time:2021-01-07 08:33:44Update time:2024-01-30 12:07:01
3s Li-Ion Battery Voltage Indicator
Based on LM3914N LED indicator IC
This project is using 5 LEDs instead of full 10pcs. Once you have calibrated the resistance value with a potentiometer, then you can remove it, measure it and place the measured resistance into "R_FIXED" axial resistor pads.
The PCB is fitted with 375mA fuse in case something becomes shorted. Also switch can be placed to the terminal block to take a measurement when you have connected this PCB to a battery with 2-pin JST connector.
REVISION: 1.0
Schematic_3s_Li-Ion_Voltage_Indicator_v1_2021-01-07.pdf
PCB_Layout_2021-01-07_top.pdf
1
PCB_Layout_2021-01-07_bottom.pdf
1
BOM_3s_Li-Ion_Voltage_Indicator_v1_2021-01-07.csv
1
Gerber_Layout_2021-01-07.zip
