ATTiny1614_breakoutBoard
STDATTiny1614_breakoutBoard
CC BY-SA 4.0
Creation time:2024-11-05 11:59:39Update time:2025-02-13 09:13:07
ATtiny1614 Breakout Board
Overview
This ATtiny1614 breakout board is designed to provide an easy-to-use and compact platform for experimenting with the ATtiny1614 microcontroller. Featuring an onboard Low Dropout Regulator (LDO), power indication, and a programmable LED, this board is well-suited for embedded development, prototyping, and low-power applications.
Features
  • ATtiny1614 Microcontroller
    • 14-pin package with a powerful AVR architecture
    • 16KB flash memory, 2KB SRAM, and 128B EEPROM
    • Multiple I/O options, including UART, SPI, and I²C
  • Power Management
    • Integrated LDO voltage regulator for stable operation
    • Accepts a wide range of input voltages (e.g., 5V or higher, depending on the regulator used)
    • Dedicated power LED for status indication
  • Programmable LED
    • Connected to PA7, allowing software-controlled visual feedback
    • Ideal for debugging or indicating system status
  • Compact and Breadboard-Friendly
    • Designed for easy integration into projects
    • Standard 2.54mm (0.1") pin headers for compatibility with breadboards and other prototyping tools
Applications
  • Embedded systems development
  • Battery-powered projects
  • Sensor interfacing and automation
  • Custom firmware experimentation
This breakout board offers a great balance between size, functionality, and flexibility, making it a solid choice for hobbyists and developers working with the ATtiny1614.
PLEASE NOTE YOU WILL NEED AN UPDI PROGRAMMER TO UPLOAD THE CODE !
Arduino library can be found here: https://github.com/SpenceKonde/megaTinyCore
Please consider supporting the work of Spence Konde !
