ROBONOMICS IR REMOTE DEV RELEASE
PROROBONOMICS IR REMOTE DEV RELEASE
3.2k
Creation time:2024-05-06 14:51:13Update time:2024-05-23 10:38:56
Universal IR Remote control
Notes for operation:
 The IR Remote  control work with any USB power supply that supports the QC2, QC3 or USB-PD (Power Delivery) specification.
 The IR remote control works on the local library and does not access the cloud.
 The IR remote control works with the Home Assistant using the MQTT protocol. To configure the device, please visit:  https://tasmota.github.io/docs/MQTT/
Hardware specification
- Weight: 36g
- Input Voltage:  DC 5V USB-C (QC2, QC3, PD)
- Standby consumption  95mA
- Viewing Angle 360°
- Wireless protocol: IEEE 802.11b/g/n (2.4 GHz Wi-Fi)
- CPU: ESP32 series of SoCs, Xtensa® dual­core 32­bit LX6 microprocessor, up to 240 MHz
- Memory: 448 KB ROM, 520 KB SRAM, 8 MB FLASH
- USB-C for firmware development and updates
Firmware:
  The IR Remote runs Tasmota, an open firmware distributed under GNU GPLv3.
  The firmware can be upgraded (flashed) via USB-C or OTA.
  IR Remote driver enables sending IR codes through an IR transmitter and receiving them through an IR receiver via [IRremoteESP8266 library](https://github.com/crankyoldgit/IRremoteESP8266).
  Most builds support only the common IR protocols, but [tasmota-ir.bin](https://tasmota.github.io/docs/Tasmota-IR/) supports almost all protocols available in the IRremoteESP8266 library.
  To learn more and download newest firmware please visit: https://tasmota.github.io/docs/
To download the firmware to this device, follow the link https://tasmota.github.io/install/
Select Tasmota IR from the drop-down list and flash the IR remote control
You can buy a housing for this device using the following links:
 - https://aliexpress.ru/item/1005004828529246.html
 - https://www.alibaba.com/product-detail/LK-AC93-Small-Mini-Wireless-Smart_1600761650010.html?spm=a2756.order-detail-ta-bn-b.0.0.56072fc2482GMt
