[Snow lantern] Color screen printing plate
PRO[Snow lantern] Color screen printing plate
Creation time:2024-11-01 03:01:00Update time:2024-11-01 06:19:01
2023/12/26 The latest version of the color silk screen snowflake lamp connection, the overall effect is more beautiful, it is recommended to make a new one.
https://oshwhub.com/lioasis/christmas-snowflake-lights#P6
This project is made by modifying the color silk screen based on the snowflake lamp made by mondraker. The original connected touch stepless dimming snowflake lamp (ceramic filament) (newbies can also make it!) - JLC EDA Open source hardware platform (oshwhub.com)
The overall schematic diagram has not been modified, and some minor modifications have been made to the PCB. You can place an order directly, or you can replace the pattern if you want.
The actual printing effect is not bad, but the board is relatively small, the pattern is also relatively small, and the pixel particles appear to be relatively large. If the board is larger, the effect will be much better.
Secondly, the color screen printing will automatically expand the solder mask window by 0.2mm to accommodate the error during production. This will cause a little white background to be exposed in the window area, but after the actual production, you will basically not notice this white background.
Designed by lioasis (from OSHWHub)
Link:https://oshwhub.com/lioasis/xue-hua-deng
