RP2040 six-axis 3D printer control panel
PRORP2040 six-axis 3D printer control panel
2.1k
Creation time:2024-10-22 06:59:20Update time:2024-10-23 06:02:20
This project is a six-axis 3D printer control board, and it is an integrated control board for the upper and lower machines. Both the upper and lower machines use the open source klipper firmware.
The onboard six-channel TMC2209 driver chip can drive six-channel stepper motors, as well as other hot beds, hot ends, thermal sensors, and fans.
At the same time, there are 3 USB interfaces onboard, which can be connected to other USB devices.
Reference video: https://www.bilibili.com/video/BV1Qp4y1E7Zq/?share_source=copy_web&vd_source=65a85cc2101a5ea7d90341ab7d3ac406
Klipper reference documentation: http://www.klipper3d.org/zh/Overview.html
Klipper Open Source Link: https://github.com/Klipper3d/klipper/
Open Source Agreement
GPL 3.0.
Project Related Functions
This project’s 3D printer control panel has the following functions:
1. Onboard 6-channel driver chip can control 6-channel stepper motors;
2. Equipped with hot bed, hot end interface, and 3-way thermal interface;
3. 3-way controllable fan interface;
4. 3-way limit interface;
5. 1-way probe or consumable detection interface;
6. 4-way USB interface, of which the back interface is the interface for connecting to the host computer and can be connected to portable WiFi, and 1-way interface is the XH2.54*4P interface, which can be connected to the tool head;
7. 1 type-c interface, used to flash the lower computer, or use USB mode to connect to the lower computer;
8. Onboard serial port chip, the upper computer uses the serial port to connect to the lower computer, avoiding the problem of unrecognizability when the RP2040 is restarted multiple times in USB mode.
This project was made public for the first time and is my original project. The project has not won any awards in other competitions.
Project Progress
Schematic drawing (completed)
PCB drawing (completed)
Hardware production (completed)
Configuration writing (completed)
Verification (Complete)
Shell (finished)
The MCU of the lower computer in this project is based on RP2040. It controls the stepper motor, hot bed, hot end and fan by connecting motor driver chips, MOS tubes and other chips; it collects temperature through the chip ADC interface; both the upper and lower computers use the currently more mainstream open source klipper system. , the upper computer connects to the lower computer MCU through the serial port, and controls the 3D printer through klipper.
RP2040 Minimal System.
USB to serial port chip, using serial port connection is more stable.
Power input and conversion 3.3V to supply power to MCU.
Stepper motor drive circuit.
Hot end heating bed control circuit.
Thermal interface, used to obtain the temperature of the hot end heating bed.
Fan control circuit, used for duct cooling, model cooling, and motherboard cooling.
Probe and limit circuit.
USB HUB circuit, expands multiple USB interfaces, used to connect peripherals.
Indicator circuit, used to determine the output status of each power supply.
Interface and wiring guidance.
Front:
Reverse side:
To install into the enclosure:
Connecting cables:
Install the printer:
Install the upper cover:
Designed by yanshimi (from OSHWHub)
Link:https://oshwhub.com/mlm520/RP2040-liuzhou
Demo video.mp4
1360
RP2040 six-axis 3D printer control board_configuration file printer.cfg
466
RP2040RP2040 six-axis 3D printer control board _ Motherboard wiring and jumper use guide.pdf
553
rp2040 6-axis 3D printer control board - Housing.stp
304
