Round LED Clock
PRORound LED Clock
Creation time:2024-11-29 03:14:42Update time:2024-12-02 02:42:26
Round Led Clock is a clock with WS2812 light strip as the display component, abandoning the common WS2812 dot matrix screen display method, using lamp beads to imitate the analog dial, 60 WS2812 lamp beads constitute the 60 points of the clock.
The main control of the project is ESP8266, with a CH340 download circuit on board, with a temperature and humidity detection, which is convenient for later development and expansion.
Original open source link:https://gitee.com/lv_tong/Round_Led_Clock
The original project was without a board, with a core board and a breadboard plug.
The board design is relatively small, and the resistors and capacitors are all 0603 packages, which is convenient for hand soldering, after all, there are not many components, and the cost of replication is relatively low.
On the basis of the original code, changes have been made, Blinker is connected, and the configuration file is in the attachment.
I tried to draw a shell with JLC EDA professional prints, it is more convenient, the shell file is placed in the attachment, and you need to pick it up.
Designed by Carryingyou (from OSHWHub)
Link:https://oshwhub.com/chengxi123/42cb4cfdc88b43a6b3b2f8e8b41f8d4e
wx_camera_1649001089617.mp4
2278
V20405-123442.mp4
2655
V20405-123348.mp4
2468
V20405-123514.mp4
1910
3D printing file .zip
173
BINs and configuration files .zip
226
