MRDK1A - 32MR_PLC Industrial Programmable Logic Controller
PROMRDK1A - 32MR_PLC Industrial Programmable Logic Controller
CC BY-NC-SA 4.0
Creation time:2025-04-18 03:31:21Update time:2025-04-21 01:14:44
EVSR{I9U[CTJ5LEZG8UHT~H
32-Channel programmable logic controller based on STM32F1 series MCU design
MCU programming software: keil 5
Ladder diagram programming software: Gxworks2
Open source license: CC-BY-NC-SA-4.0 (This product is only for PLC working principle, programming learning, teaching use, and is prohibited for any form of commercial use)
Basic parameters: Power supply: 220V-0.3A
Output mode: relay
Input range: 5~ 24V
Output touchpoint capacity: AC250V-5A DC310V-3A
Number of output units: 32 (IN: 16P---OUT: 16P)
Series product naming:
The default is relay output. If you need transistor or thyristor output, you can directly replace the mechanical relay with a solid-state relay, or redesign the output unit.
The main control uses the STM32F1 series MCU, which can port programs to other platforms or add and delete units. The selected MCU: RAM memory should not be less than 48K, and Flash memory should not be less than 256K.
Host peripherals and communication unit.
The main power supply (when selecting the inductor of L1, attention should be paid to the DCR value below 20mΩ). If it is higher than that, it will cause the DC-DC to generate a large amount of heat in the working state (which may affect the long-term stability).
IO unit circuit
Output drive principle: MCUIO > > Optocoupler isolation > > 2803 drive > > Relay
Input driver: 5~ 24V signal > > Optocoupler isolation > > MCUIO
PCB-3D
Shell
During the initial testing, it was found that the indicator light had been forgotten to be opened, so a transparent shell was installed, and subsequent files have been corrected.
IMG_20250402_232949
IMG_20250402_232148
Laser sintered nylon shell
IMG_20250402_233604
If used under harsh conditions, it is recommended to add a shielding cover to the control circuit to enhance its anti-interference ability under harsh conditions.
OX[~@6N1JODKHW[DQ0T8DIU
IMG_20250402_211839
Sheet metal shell plate thickness should be 0.1~ 0.2mm JLC sheet metal minimum can only be 0.5mm, if 0.5mm plate thickness should be welded with the main board installation.
The back shell is fixed with reeds and C45 guide rails.
Spring: 0.6 * 4 * 15.
IMG_20250402_232921
IMG_20250402_232929
RTC clock battery.
Gxworks2 configuration instructions.
In Gxworks2 PLC model selection FX2N create project.
Communication selection: RS232 communication, and select the corresponding serial port.
PLC Test Procedure 1: Three Motor Sequential Start and Stop.
PLC test program 2: running light (delay 1s)
Test video: https://www.bilibili.com/video/BV144f3YcEp8/?vd_source=f2ecf6d07c56387a85d94b5338693a63
Program, shell, routine see engineering attachment
IMG_20250323_182502
IMG_20250402_232150
IMG_20250402_233637
Link:https://oshwhub.com/dingcheng/mrdk1a-16mrplc-industrial-progra
MRDK-1A_32MR.hex
96
running lights.gxw
68
Three-motor sequential start and stop.gxw
69
shell .zip
82
MRDK1A-32MR.zip
202
