JLC electrothermal film - mini desktop heater
PROJLC electrothermal film - mini desktop heater
Creation time:2025-03-24 07:35:55Update time:2025-03-25 01:32:28
Brand new version, if you're a brother, come and replicate it!
Heater overall size: 60 * 28 * 75. (Unit: mm)
The heating element of this heater uses the PI electric heating film of Jiali Chuang electric heating film. Thanks to the high customization of JLC electric heating film, the size of the heater is more mini and portable, and the performance has also been improved. Most importantly, when ordering Jiali Chuang electric heating film, you only need to upload the corresponding heating element shape file, and the wiring is completely handed over to professional engineers. You only need to place the order, and the rest is left to Jiali Chuang electric heating film. After placing the order, you can also view the corresponding temperature curve. If there are no special requirements, you don't need to test it yourself. It's really super convenient.
Friends who want to replicate can refer to the following process information or order page remarks: M2502270021 + mini desktop heater, you can order the same heating element.
===== Appearance display =====
I won't go into detail about the circuit part, it's just a very simple NE555 variable duty cycle pulse generation circuit. The calculated frequency is just right for the hot chip, but the fan is noisy when the duty cycle is low. Then, I will show you some precautions.
===== Precautions =====
1. When making hot film samples, you must choose the type that requires adhesive backing and the type that requires welding wire. As shown in Figure 1, the diameter of the welding wire is also thoughtfully provided in the current comparison table on the JLC electric heating film ordering page, as shown in Figure 2. Please fill in the specific information according to your needs. (For example: My power supply current is 2A, and I usually choose a specification of 2A or above. It should be large rather than small, but not too large. It is enough.)
Figure 1
Figure 2
2. Not only do you need to sample the electric heater (Figure 3), but also you need to sample the aluminum-based PCB (Figure 4) and purchase the aluminum heat sink (Figure 5). For engineering, you need to place an order for both PCB boards (both sample rolls can be used). The heat sink we received is a thin piece (Figure 3) with adhesive backing. We need to paste it on the aluminum-based PCB, otherwise the PI electric heater film is flexible and difficult to fix. Finally, you need to paste the heat sink on the heat sink (Figure 6), and the position of the heat sink paste is shown in Figure 8.
Heat sink link: https://e.tb.cn/h.TzWbEsgGQk9kPez?tk=xisIeLt6fz7 (specification: 10 * 10 * 10 mm)
Figure 3
Figure 4
Figure 5
Figure 6 (Solder joint edge down one centimeter, paste in order)
The heating element is fixed to the M2 * 22 bolt by connecting two M2 studs and two M2 * 3 * 3.2 injection-molded copper nuts. Then it is fixed to the bracket through an injection-molded nut, as shown in Figure 7. (Installing the heating element to the bracket may be a bit difficult, so please do it twice more. The link is attached for everyone. Try to buy from the same store to save shipping costs).
Figure 7
4. As shown in Figure 8, after welding these two places, it is necessary to cut or polish them flat with pliers, otherwise the fan will be tilted.
Figure 8
5. Schematic diagram of connection (only one MOS tube needs to be welded, and the fan and hot plate are connected together)
Figure 9
6. When testing or using, be sure to pay attention to safety. Although the area is so small, the temperature of the heating element with a power of 24W is very high. Be sure to pay attention.
7. Due to the excessive heat dissipation applied to the heating film, the temperature test and the predicted temperature will be inconsistent. The trend is about 50 ℃, and it feels warm when blown on the hand.
The order documents for electric heating film and aluminum-based PCB are attached.
List of originals
Name Specifications Price Quantity Quantity required for the project Link
JLC electric heating film 60*15mm ¥20 * 1 JLC electric heating film
Aluminum-based PCB heat sink 60*15 * 1 1 LC Order Assistant
Turbo fan Micro 3010, 12V, 5000 rpm ¥4.50 2 2 [Taobao] CZ001 "Micro 3010 Turbo Blower 5V/12V/24V Purifier Centrifugal Fan, Hydraulic High Rotation Cooling Fan"
Single potentiometer B500k ¥2.77 2 1 [Taobao] "RK097NS single and double potentiometer small B5K/10K/20K/50K/100K power amplifier volume audio speaker"
Heat sink 10*10*10mm ¥6.50 20 8 [Taobao] "Heatsink aluminum strip adhesive free shipping, electronic main board IC chip aluminum block MOS memory heat sink with heat conduction sticker"
Ship switch KCD11 10 * 15mm 2 feet 2 gears ¥2.07 5 1 [Taobao] "Ship-shaped switch, small KCD1 electric frying pan, water dispenser, electronic scale, ship-shaped rocker, power button, button accessories"
Click directly on "Place Order on Lichuang Mall" for the remaining originals.
Hardware
M2 screwdriver M2*22mm ¥3.03 50 4 [Taobao] "304 stainless steel round head bolt disc head cross bolt round head machine tooth bolt small bolt M2M3M4M5M6"
M2 nut M2 ¥4.64 100 4 [Taobao] "304 316 stainless steel hexagon nut nut nut nut nut nut cap complete
Injection molded copper nut M2*3*3.5 ¥1.19 30 6 [Taobao] "Injection-molded copper nut M2M2.5 copper embedded parts M3M4 inlaid parts M5M6 knurled nut copper flower mother M8 imperial"
    ¥44.70
Annex explains
File name Purpose
3D Shell .zip Heater housing 3D file, upload when 3D printing
Heating element dimension.zip Heating film size DXF Compressed Packet, upload when ordering electric heating film
Installation demonstration of hot plate bracket.mp4 Demonstration video of heating plate installation to bracket
Assemble Animation Demonstration.mp4 Overall installation demonstration video
Designed by zzron (from OSHWHub)
Link:https://oshwhub.com/zzron/mini_warm-air-blower
Assemble the animation demonstration .mp4
1
The size of the heating element .zip
3D shell .zip
Hot sheet bracket installation demonstration .
