Intelligent High-Power Electronic Load
PROIntelligent High-Power Electronic Load
Creation time:2025-04-30 08:32:10Update time:2025-05-06 02:15:00
Intelligent high-power electronic load based on AT32F435, supporting external temperature sensors, program control, scripts, offline logs, CAN expansion, cool UI, etc.
1. Preface:
Electronic load is already a well-known thing, so why do we still need to do it? Yes, what others do is too rubbish. I mean, everyone who is doing it is rubbish. So here comes the high-power intelligent electronic load. Firstly, it has sufficient power, stable 300 watts, CPU-level 3 fans and 6 copper tube professional heat sinks. Secondly, it is intelligent enough to support CAN bus interconnection, script programming, external NTC, PTC, serial port screen and other data collection and display. Later, consider 4 tubes, 600W and wireless functions.
2. Introduction to the plan
In order to be intelligent enough, cheap microcontrollers must be abandoned first, and a more powerful AT32F435 is selected to run LVGL smoothly, provide a cool GUI interaction experience, and have enough flash memory and memory to run the script environment
2.1 AT32 minimum system
Designed high-speed external crystal oscillators and low-speed external crystal oscillators, providing accurate system clock and timing functions, supporting BOOT0 independent settings, battery interfaces, etc
2.2 1.47 Color screen interface
Onboard 1.47-inch color screen, SPI interface, resolution 320 * 172, supports independent backlight adjustment, and can also connect larger screens and touch functions through the board interface.
2.3 Memory card interface
Used for storing offline logs, selecting scripts, etc
2.4 Buzzer interface
2.5 CAN bus interface
2.6 SPI FLASH
2.7 Lithium battery charging port
2.8 USB HOST interface
2.9 Debug interface
2.10 Expansion interface
2.11 Voltage acquisition circuit
The voltage acquisition circuit is divided into four groups, which respectively collect the system power supply (12~ 36V, which supplies power to the whole machine, including the cooling fan, with high power consumption), the input power supply (that is, the power supply input is used as the load), the system 5VDCDC voltage (USB power supply unidirectional input), and the lithium battery voltage.
2.12 System DCDC
The system DCDC is divided into 12V and 5V. 12V is powered by the cooling fan and comparator, and 5V is powered by the buzzer and 3.3V LDO.
2.13 Fan interface
Support three-wire and four-wire interface fans, support speed regulation and speed measurement functions.
2.14 MOS Load Circuit
The following is the most essential part of the circuit. The input power supply is connected to the 100A fuse through the F1 and F2 seats, and then the current is evenly distributed through the two MOSFETs Q4Q5. After testing, the actual test power of a MOSFETT is about 150W. If it exceeds, it will be damaged. Therefore, 300 watts can be achieved through the two-tube current sharing method. The output current of Q4 passes through the input comparator U20 through the sampling resistor R26 through the R72 limit viewership. The output of Q5 also passes through the comparator U5. The high-side voltage of the two comparators comes from the U7 follower, and the reference voltage comes from the DAC1 of PA4. After being divided by R18 and R24, the maximum voltage of 97mV is obtained, corresponding to about 97A current. When the current exceeds 50A, the measurement range is switched through Q8, and the current resolution is about 33mA due to the low accuracy of the built-in ADC.
3. Software development
Software developed using MDK5, bare metal program
File grouping user: main function
File grouping bsp: hardware driver
File grouping firmware: MCU firmware library
File grouping lvgl: lvgl library
File grouping USB: USB library
File grouping fatfs: file system library
File grouping lua: script library
Introduction to bsp function: Platform is the MCU board-level bottom driver, such as system tick timer, system time base, debug serial port, etc. MCU platform-related initialization, lcd is screen initialization, IO is hardware interface initialization, including IO, SPI, IIC, timer, ADC, DAC, CAN, etc. Initialization, app is the application layer, pid has been deprecated, flash is the MCUFLASH operation part, sdcard is the memory card driver, using SPI interface, malloc is memory allocation, used to initialize the memory environment for lua script, i2c_app is the hardware IIC test function, deprecated.
The program uses software timers to manage foreground processes. The main loop is responsible for USB host polling, and the USB mouse is used to control the UI. The 50ms cycle task is used to switch UI interfaces and control DAC load currents. In the future, UI interaction and Lua interfaces will continue to be optimized. Stay tuned!!!
The program attachment cannot be placed, put it in gitee: https://gitee.com/lovelessing/electronic-load.git
4. Replication steps
If nothing unexpected happens, the board in hand should look like this, and it is basically welded
The back of the solder mask window current enhancement can be repaired if conditions permit (if the current exceeds 50A).
Then install the radiator base with M4 screws and download the program
The current enhancement of the solder mask window on the back can be repaired if conditions permit (if the current exceeds 50A).
Then install the radiator base with M4 screws, and then download the program.
You also need to remove the default NTC resistor, replace it with a long pin, and then twist it to place the head slightly higher than the MOS to ensure that the heat sink can press down on the NTC. It is best to also apply thermal conductive silicone grease to the NTC.
213 watt test, the temperature rose to more than 50 degrees in minutes (power needs to be limited under high voltage, otherwise MOS is easy to burn)
Designed by lovelessing (from OSHWHub)
Link:https://oshwhub.com/lovelessing/intelligent-high-power-electroni
Electronic Load V1 firmware.hex
14
VID_20250319_160030.mp4
VID_20250319_165023.mp4
VID_20250320_094219.mp4
