High power micro desktop charging dock
PROHigh power micro desktop charging dock
Creation time:2024-12-19 02:53:26Update time:2024-12-26 03:11:44
The project is complete and verified.
The size is close to that of a credit card.
Input:
DC 24V-32V
Output:
Type-C 140W x1 140w
Type-C 100Wx2 100w
Type-C 65W x2 sw3526 x2 65w
USB-A 65W x6 sw3526 x6 65w
The total power is 840W
The 140W Type-C port uses the sw3556 x1.
Support PPS/PD3.0/PD2.0 QC5/QC4+/QC3+/QC3.0/QC2.0 AFC FCP High and Low Voltage SCP PE2.0/PE1.1 SFCP TFCP Apple/Samsung High Current Charging Mode.
The 100W Type-C interface uses the sw3517s x2
Support PPS/PD3.0/PD2.0 QC4+/QC4/QC3.0/QC2.0 AFC FCP SCP PE2.0/PE1.1 SFCP Apple/Samsung high current charging mode.
The 65W Type-C interface uses sw3526 x2.
Support PPS/PD3.0/PD2.0 QC4+/QC4/QC3.0/QC2.0 AFC FCP low/high voltage SCP PE2.0/PE1.1 SFCP Apple/Samsung mode.
The 65W USB-A port uses sw3526 x6.
Manufacturing Instructions:
When proofing, use the top plate, the bottom plate, or the top plate.
Shell, please search for "aluminum alloy shell" on Taobao, sort by price, the cheapest one is; Size: 20*50*80.
The fast charge indicator does not need to be soldered—it is not utilized.
Power design, pay attention to heat dissipation, it is recommended to cover the batch with a thermally conductive silicone pad between the shell.
Designed by Zhang_TTL (from OSHWHub)
Link:https://oshwhub.com/zhang_ttl/Desktop_charging_dock
