ESP32C3 single mode Bluetooth keypad ZY-17W
PROESP32C3 single mode Bluetooth keypad ZY-17W
Creation time:2024-11-22 03:02:04Update time:2024-11-22 06:26:36
1. Finished product effect display
For specific functions and details, please watch the video of Station B:
[Open source]17-key Bluetooth keypad knob + slider + RGB support hot-swappable/full-key rollover/low-power hibernation_Bilibili_bilibili
2. Preparation of materials
(1) Core board: Hezhou ESP32C3 simple model (the classic model is theoretically feasible and not tested)
(2) Lithium battery: the size is not more than 90x55x6mm (length x width x height), the capacity can be selected according to the needs of battery life, and the joint form is 1.25 black and red.
(3) PCB: direct export, DRC check error-free.
(4) Other electronic components: see the BOM list, some problems can be judged by yourself.
The following station B silently _v the list of materials that helped organize it can also be used as a reference.
(5) Keyboard components: keyboard switch body x17, 2U satellite axis x3, keycap in keypad area 1 set, knob cap x1 (selected according to knob connection form)
(6) Shell: 3D printing, see attachment for printing documents.
(7) Screws: Flat head screws (diameter x length) 2x4mm quantity 4 2x14mm quantity 4.
3. Production process
3.1 Component soldering
As shown below, solder the components and install the lithium battery.
3.2 Burning program
Use the Arduino IDE to burn the program and test the keyboard function, the program related content will be introduced later.
3.3 Installing the Backshell
Fix the PCB to the bottom case with 2x4mm screws.
3.4 Installing the Top Case
The top shell is secured to the bottom shell by means of 2x14mm screws.
3.5 Install the shaft body, keycaps, and knobs
As shown in the figure below, the shaft body, keycaps, and knob caps can be installed, and the housing can be painted as needed, and three 2U satellite shafts are required here.
4. Description of the Procedure
4.1 Compilation Environment Support
This keyboard is developed based on the Arduino IDE, so you need to install the corresponding esp32 development board package, and there are many online tutorials, so I will not repeat them here. The configuration of the device is as follows, because the simplified version of the ESP32C3 core board is used, so the download method is "Internal USB".
4.2 Instructions for Using the Library
For keyboard functionality, you need to add the following libraries to Arduino:
(1) WS2812FX library to achieve RGB effect.
(2) NimBLE-Arduino library to make BLE implementation more lightweight.
(3) ESP32-BLE-Keyboard library to realize Bluetooth keyboard function.
Link: https://github.com/T-vK/ESP32-BLE-Keyboard
Note: You need to add a #define USE_NIMBLE at the beginning before or after installation to enable NimBLE.
If there is a problem with the compilation of this library, you can use the program files with the keyboard library provided in the attachment (other libraries still need to be installed)
(4) TaskScheduler library to enable multitasking
4.3 Compiling and Downloading
After the compilation is successful, connect the development board with a USB cable to download.
5. Function Introduction
The detailed operation method and effect can be found in the video of Bilibili.
5.1 Key Functions
This keyboard is only a single-mode Bluetooth keyboard, currently does not support key change, suitable for Windows system, the key area supports Num Lock mode switching.
5.2 Knob Function
The knob is used to adjust the RGB lighting effect of the keyboard, and the functions are shown in the table below.
Knob operation Effect
Tap (with lights on) Toggle the light mode
 Tap (with lights off) Turn on the lights
Press and hold Turn off the lights
Rotate clockwise Reduce the brightness of the light
Rotate counterclockwise Increase the brightness of the light
5.3 Touch slider function
The touch slider is used for multimedia control, and the functions are shown in the table below.
Touch operation Effect
Swipe from bottom to top and hold Volume up
Swipe down from top to bottom and hold The volume decreases
Swipe from the bottom to the top (do not hold with long press) Previous one
Swipe from top to bottom (don't hold with long press) Next one
Tap it Pause/Play
Press and hold the lower middle of the slider Mute/sound
Press and hold the upper part of the slider Disable/enable the slider feature
*The principle of the slider here is only based on the judgment of the touch switch, and cannot accurately judge the touch position, which is considered a pseudo-slider.
5.4 Low Power Mode
(1) When the switch at the bottom of the two switches on the back of the keyboard is turned to ON, if the keyboard is not operated within 20min, it will enter the low-power mode by itself. The duration of entry can be defined in the program;
(2) If you want to operate the switch externally after the installation is completed, you need to open the bottom shell opening before installation;
(3) After entering deep sleep (after low power mode), you can wake up by touching the slider or pressing the knob, because the Bluetooth of the keyboard is turned off in low power consumption mode, it is necessary to wait for the Bluetooth connection (3~5s) button to respond after waking up.
(4) The power consumption in each case is shown in the following table, taking the power supply voltage of 3.7V as an example.
State The magnitude of the current Test
No light operation mode About 93mA 4t65nnzc3GjckSXJ8hO5pQcAsaMqo6QBSAy9lVq3.jpeg
Low brightness mode of operation
About 105mA
(related to display color)
High brightness mode of operation
140~230mA
*The power consumption of ESP32 series Bluetooth is indeed quite high, and there will be an opportunity to try to use Qinheng's chip development later.
Designed by SMALL_DA (from OSHWHub)
Link:https://oshwhub.com/small_da/ESP32C3-dan-mu-lan-ya-jian-pan
The shell model file .zip
488
Procedure .zip
584
The program (keyboard library included) .zip
486
