ESP32-S3 DTU edge gateway
PROESP32-S3 DTU edge gateway
Creation time:2024-12-24 03:42:30Update time:2024-12-24 07:15:54
Bilibili display video: https://www.bilibili.com/video/BV1m4pEe2EN6/?pop_share=1
Project Brief Introduction
Based on Espressif's ESP32-S3 module, this project designed a DTU edge gateway. The high performance and low power consumption of the ESP32-S3 chip are used to build a device that can realize remote data transmission, real-time monitoring and control functions. The project is suitable for smart home, industrial automation and other fields, and supports networking and data transmission to the cloud through the built-in WIFI of the chip and the Ethernet interface of the SPI plug-in.
Core features
Edge computing
Taking advantage of the performance of the ESP32-S3, it can be redeveloped to collect data from various sensors or devices and upload it to the cloud for further processing and analysis.
Data collection is migrated to the cloud
Through the WIFI/Ethernet interface on the module, the device can be connected to the Ethernet and support the transparent transmission of data from RS485/TTL to TCP. (Other software functions are being implemented)
Serial terminal
Users can access the module terminal through the USB interface, and configure the relevant parameters of the module through the command line.
ESD protection
RS485/CAN and power interface are equipped with TVS tubes, which can prevent abnormal overvoltage damage to the circuit board.
Peripheral interfaces
24V input.
WIFI/RJ45 10M/100M Ethernet networking.
RS485 interface*2
TTL interface*1
CAN interface*1
Output interface*2
Input interface*2
Hardware solutions
Main control ESP32-S3-WROOM-1U
24V-3.3V SGM6232
RJ45 Ethernet CH390
RS485 UMW SP3485
CAN SIT65HVD232DR
Input interface: PC817 opto-decoupled isolated input
Output HF46F-024-HS1 24V relay driven by ULN2003
Original purchase link
Some originals are more difficult to purchase, you can refer to the link below to purchase:
SGM6232
https://item.taobao.com/item.htm?_u=92dklb455582&id=583922757198&spm=a1z09.2.0.0.10d92e8dAOrZiH
HF46F-024-HS1
https://item.taobao.com/item.htm?_u=92dklb45eb26&id=566157069101&spm=a1z09.2.0.0.10d92e8dAOrZiH
RJ45 interface HR911105A
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.10d92e8dAOrZiH&id=717161946752&_u=92dklb4592b3
CH390H:
https://item.taobao.com/item.htm?_u=92dklb45f1d6&id=731963286951&spm=a1z09.2.0.0.10d92e8dAOrZiH
Power supply scheme
1. DC power supply
2. 24V switching power supply
3. Powered by 24V DC adapter
DC power cord reference purchase link (0.75 flat DC5521 female cable - 30 cm):
https://item.taobao.com/item.htm?_u=92dklb45b928&id=600480775477&spm=a1z09.2.0.0.1b8d2e8dzMqIED
24V power supply reference purchase link (Color classification: 24V2A [Big head 5.5MM] 3C certification) :
https://detail.tmall.com/item.htm?id=645461549857&spm=a1z09.2.0.0.1b8d2e8dzMqIED&_u=92dklb4518a8
Connector purchase link
3.81(for data interfaces)
https://item.taobao.com/item.htm?_u=92dklb4538cc&id=522575305943&spm=a1z09.2.0.0.4a072e8dlUj9VZ
5.08(for data interfaces)
https://item.taobao.com/item.htm?_u=92dklb4595f7&id=522579348831&spm=a1z09.2.0.0.4a072e8dlUj9VZ
Rail mounting
The 3D enclosure is perforated and installed using third-party connectors.
https://item.taobao.com/item.htm?from=cart&id=671947800707&skuId=5016817435573&spm=a1z0d.6639537/202406.item.d671947800707.406b7484wncj4i
https://item.taobao.com/item.htm?from=cart&id=660426609931&skuId=4762019120810&spm=a1z0d.6639537/202406.item.d660426609931.406b7484wncj4i
3D printed shell
6 hot melt nuts are required to print the bottom shell of the shell, and the nut purchase link is referred to below (choose M3*4*4.2 [100 pieces]):
https://detail.tmall.com/item.htm?_u=92dklb45dc00&id=598418504681&spm=a1z09.2.0.0.10d92e8dAOrZiH
Screw Reference Link (M3*5 Hexagon Flat Head):
https://detail.tmall.com/item.htm?_u=92dklb45b024&id=624811454452&spm=a1z09.2.0.0.10d92e8dAOrZiH
List of attachments
Shell file
Shell bamboo slices .3mf
Upper shell. STEP
Lower shell. STEP
Module program source code (under development, need to use ESP-IDF to compile and download)
s3-ch390h.7z
Internet speed test tool
iperf.zip
Display pictures
Designed by FanHuaCloud (from OSHWHub)
Link:https://oshwhub.com/fanhuacloud/esp32-s3dtu
39
Upper shell. STEP
33
Lower shell. STEP
32
s3-ch390h.7z
100
iperf.zip
64
