[Embedded] Dream One - Intelligent car design based on STC32
PRO[Embedded] Dream One - Intelligent car design based on STC32
Creation time:2024-10-25 10:06:06Update time:2024-10-29 09:27:20
1. Project Introduction
If I had any dreams as a child, it would probably be to have my own four-wheel drive. In order to realize the dream of building a car with everyone, we combine circuit learning, PCB design, welding and microcontroller development to explain how to make a handsome smart car in the form of videos and documents, truly achieving zero-based learning , we named this car: Zhumeng No. 1.
2. Function Introduction
To build an excellent four-wheel drive car, its functions must be powerful. Zhumeng No.1 has the following eight core functions. Each function corresponds to the knowledge points of the microcontroller. Through studying Zhumeng No.1, at the same time Master the ability of microcontroller development.
(1) Place two LEDs on the front of the car to simulate the car lighting system and learn the output function of the microcontroller;
(2) Use independent buttons to simulate the car's one-button start function and learn the input detection of the microcontroller;
(3) Passive buzzer music is generated, making driving less boring and learning timer function configuration;
(4) What to do if there is no power on the road? Use the battery voltage detection function and learn the ADC voltage acquisition function;
(5) Four motors are independently controlled to realize the car walking, learning motor drive and PWM output functions;
(6) There are obstacles ahead. Ultrasonic obstacle avoidance makes the car drive safer and learn how to use sensors;
(7) Infrared photoelectric tube to realize the car’s driverless tracking function and learn how to use the sensor;
(8) Use the Bluetooth module to control the driving of the car through the mobile phone APP, and master the serial port protocol and data transmission;
3. Skill Mastery
In the learning process of Zhumeng No. 1, every step from hardware design to software programming is crucial. To become an excellent electronic engineer, you not only need to master circuit design, but also need to master PCB design, welding, code writing, etc. Basic literacy, through learning Zhumeng No. 1 four-wheel drive smart car, not only allows you to build a car, but also hopes to master the development capabilities of microcontroller projects through learning the car.
(1) Learn the methods of circuit analysis for microcontroller projects and learn how to understand schematic diagrams;
(2) Learn microcontroller circuit design methods, and initially master component selection and data manual reading;
(3) Master JLC EDA design schematics and PCB methods, and design your own smart car;
(4) Master the basic methods of component welding and hardware debugging skills, and become a new generation of " Welding Emperor " ;
(5) Learn the basic functions and peripheral use of STC32 microcontroller, and get started with STC32 project development;
(6) Master the methods and techniques of embedded software development, code reading and bug debugging.
4. Study Course Outline
Part One: Nine Lectures on Hardware Design of Zhumeng No.1 Intelligent Car
Course content Course details Video learning
Hardware Lecture 1: First introduction to smart cars
  • Introduce the learning route and overall plan.
😃Click to watch
Hardware Lecture 2: Smart Car Circuit Analysis
  • Detailed analysis of the circuit of Zhumeng No. 1 smart car.
😃Click to watch
Hardware Lecture 3: Component Selection and Schematic Drawing
  • Learn JLC EDA and device selection and schematic drawing methods.
😃Click to watch
Hardware Lecture 4: Schematic Design Inspection and Optimization
  • Understand common problems in schematic design and learn schematic organization and optimization methods.
😃Click to watch
Hardware Lecture 5: Smart Car Appearance Design
  • Master the key points of board and frame design and learn to design personalized board shapes.
😃Click to watch
Hardware Lecture 6: Smart Car PCB Layout
  • Master the principles and key points of PCB layout and lay out the smart car.
Hardware Lecture 7: Smart Car PCB Routing
  • Master the principles and key points of PCB routing, and conduct PCB routing for smart cars.
😃Click to watch
Hardware Lecture 8: PCB Design Inspection and Optimization
  • Understand common problems in PCB design and learn PCB organization and optimization methods.
😃Click to watch
Hardware Lecture 9: PCB Ordering and Component Purchase
  • Learn to export production files, understand PCB order proofing and component procurement.
😃Click to watch
Part 2: Nine lectures on welding and assembly of Zhumeng No. 1 smart car
Welding Lecture 1: Introduction to Welding Tools
  • Introducing commonly used welding tools and how to use them.
😃Click to watch
Welding Lecture 2: Welding of Inline Resistors
  • Master the soldering and pad hole processing methods of in-line resistors.
😃Click to watch
Welding Lecture 3: Welding of Diodes
  • Master the diode positive and negative direction identification and welding methods.
😃Click to watch
Welding Lecture 4: Transistor and Buzzer Welding
  • Master the identification of transistor polarity and the soldering method of dense pin plug-in.
😃Click to watch
Welding Lecture 5: Welding of Tracking Circuit
  • Master the identification and welding of the pin directions of direct plug-in chips and photoelectric sensors.
😃Click to watch
Welding Lecture 6: Power Circuit Welding
  • Master the distinction between positive and negative poles of plug-in aluminum electrolytic capacitors and the installation of heat sinks.
😃Click to watch
Welding Lecture 7: Minimum System and Module Welding
  • Master how to make the welding standards of pin headers and female headers neat and not crooked.
😃Click to watch
Welding Lecture 8: Motor Drive Chip Welding
  • Master the identification, drag soldering and disassembly skills of chip component chip pins.
😃 Click to watch
Welding Lecture 9: Motor Welding and Fixing
  • Master the motor fixation and direction testing methods, and perform the final assembly of the car.
😃Click to watch
Part Three: Nine Lectures on Program Development of Zhumeng No.1 Intelligent Car
Programming Lecture 1: LED driver to make car lights flash
  • Master the configuration of STC32 pins and the packaging and calling of delay functions.
😃Click to watch
Programming Lecture 2: Input detection, key mode switching
  • Master the principle of key debounce and the function of key control mode.
😃Click to watch
Programming Lecture 3: Doremifa, buzzer music playback
  • Learn the application of timer and realize the driving of passive buzzer.
😜Stay tuned
Programming Lecture 4: Low battery, ADC detection experiment
  • Learn the ADC detection principle and realize power detection and alarm functions.
😜Stay tuned
Programming Lecture 5: Motor drive to make the car run
  • Learn motor drive and PWM to realize the car driving function.
😜Stay tuned
Programming Lecture 6: Intelligent Collision Avoidance, Ultrasonic Obstacle Avoidance Detection
  • Learn the principle of ultrasonic obstacle avoidance and realize the obstacle avoidance function of the car.
😜Stay tuned
Programming Lecture 7: Intelligent Driving, Infrared Tracking Control
  • Learn the principle of infrared tube tracking and realize the car driving along the line.
😜Stay tuned
Programming Lecture 8: Wireless Control, Bluetooth Transmission Experiment
  • Learn the principles of Bluetooth transmission and learn to design Bluetooth APP to control the car.
😜Stay tuned
Programming Lecture 9: Smart Car Subject 2 Practical Training
  • Completed the comprehensive training in the second venue of the smart car subject and successfully received the certificate!
😜Stay tuned
5. Supplementary Information
(1) STC32G12K128 core board project link
(2) STC32 core board design teaching video
(3) STC32G12K128 core board software teaching video
List of different styles of Zhumeng No. 1 STC32 smart car, which one do you like~
bluetooth.apk.1.1
1736
STC32 Dream One intelligent car reference code
4299
Zhumeng No. 1 STC32 smart car project hardware design document
3366
