ElectronBot voice version
PROElectronBot voice version
CC BY-NC 4.0
Creation time:2024-10-31 02:46:39Update time:2024-10-31 07:27:25
# Distributed under the Creative Commons Non-Commercial License (CC BY-NC 4.0).
# You may copy, distribute, and disseminate this work, but only for non-commercial purposes.
# For use in commercial products, please contact the author for authorization.
Based on the head PCB board of electronic robot, an open source project of Zhihui Jun, the FPC cable arrangement was changed, and a language version interface was added. After testing, it can be used normally. The connection cable with the head board was replaced with 10P, so No drilling is required, making it easier to assemble. It replaces the TF card holder with the same small size. It has been verified and available. Now the voice version and the normal version are combined into one. You only need to change the bottom PCB. Switching between the voice version and the normal version is easier to assemble than the original PCB. The voice version does not need to polish the casing and is more elegant to assemble. It can achieve zero gaps. At the same time, other functions will be continuously updated in the future. Voice. The function requires the following PCB. All FPC cables used are in the same direction. The connection between the head and the sensor board uses 10P in the same direction, and the length is 10cm. The USB connection with the sensor uses 8P in the same direction, and the length is 6cm.
Assembly Video
https://www.bilibili.com/video/BV1us4y197g5/?spm_id_from=333.999.0.0&vd_source=fa73f76f180547c9451caa5496bf5bbb
You can also go to the QQ group: 147597938 to get a detailed component list. If the driver will not be installed, please refer to the link below: https://pan.baidu.com/s/1BxRbZ64vqr05anxQX_4iDQ
PWD:n9gt
Designed by 小卡 (from OSHWHub)
Link:https://oshwhub.com/taosi/ElectronBotyu-yin-ban
