【 Blue Bridge Cup 】 The 13th Blue Bridge Cup microcontroller design and development project national competition
PRO【 Blue Bridge Cup 】 The 13th Blue Bridge Cup microcontroller design and development project national competition
Creation time:2025-02-18 02:01:16Update time:2025-02-19 01:37:39
1. Project Introduction
The 13th Blue Bridge Cup MCU Design and Development Project National Competition, based on the four-ladder/Guoxin Changtian MCU competition training platform provided by the organizing committee, modified the configuration according to the requirements of the competition, and drew a practice training board that meets the basic requirements.
2. Hardware block diagram
Figure 1 is the hardware block diagram in the description file, which is mainly divided into single-chip microcomputer, button, pulse, ultrasonic, LED, AD/DA, E2PROM, and digital tube display.
Fig.1 Block diagram of system hardware
3. Detailed explanation of the module
According to the hardware block diagram of the competition description file, the configuration is carried out with reference to the device package of the CT107D MCU competition training platform, and the hardware schematic diagram is deleted and modified on the basis SCH_of the hardware schematic diagram in the DIP_SCM_2022 directory in the electronic resource data package of the 13th Blue Bridge Cup Competition. Don't make too many changes, try to be compatible with the official training platform of the Blue Bridge Cup.
Fig.2 CT107D MCU competition training platform
Fig.3 SCH_CT107D MCU competition training platform V20
Fig.4-1 V30_MCU of the SCH_CT107D MCU competition training platform
Fig.4-2 V30_USB_SerialPort of the SCH_CT107D MCU competition training platform
Fig.4-3 V30_P0_EX of the SCH_CT107D MCU competition training platform
Fig.4-4 V30_USER of the SCH_CT107D MCU competition training platform
Fig.5 SCH_ the national competition of the 13th Blue Bridge Cup single-chip microcomputer design and development project
  • MCU chip: The main control MCU uses the IAP15F2K61S2 chip designated by the Blue Bridge Cup MCU Competition;
  • Power Module:DC power socket and TYPE-C, provide 5V DC power supply;
  • Control buttons: keep four buttons to realize the switching, addition and subtraction of interface parameter modes;
  • Display module: realize the mode status prompt function through LED indicator;
  • Digital tube module: The digital tube display uses a 0.36-inch common yang digital tube for interface display of frequency, humidity, distance and other parameters;
  • Ultrasonic module: The ultrasonic circuit is modified and replaced with the HC-SR04 module, which simplifies the circuit and is easy to use, and the ultrasonic sensor realizes the ranging function;
  • Signal generation module: NE555 pulse signal generation circuit is composed of a pulse signal generation circuit to generate the pulse signal required for the experiment;
  • ADC/DAC module: The AD/DA conversion circuit measures and adjusts the output voltage of the potentiometer through the PCF8951 ADC/DAC channel;
  • Storage/IO expansion: E2PROM uses AT24C02M to count the number of relay switches and save the data in the address;
  • MM/IO mode channel selection: 74H138 decoder and 74HC02 NAND gate device, WR and P42/WR short-circuit MM mode; WR is shorted to ground in IO mode;
  • Program download: onboard USB to serial port function, which can complete the serial communication and download between the single-chip microcomputer and the PC, and also leave the pin header download interface;
  • Other modules: relays, photoresistors and temperature sensors required for the competition, extended pin headers and M3 screw holes;
4.Bill of materials
BOM_ the 13th Blue Bridge Cup MCU Design and Development Project National Competition
NO.
Name
Parameter
Device designation
Quantity
Encapsulation
Item number
1
Resistance
1
R1,R8~R23
17
R0805
C17513
10
R2,R4~R6,R24,R26~R29
9
C17414
510Ω
R3
1
C17734
300Ω
R7
1
C17617
100Ω
R25
1
C115423
Capacitance
1uF
C1
C0805
C111768
100nF
C3,C5,C6,C11,C13,C14
C1711
10pF
C7~C10
C157608
47uF
C2,C4
SMD,5x5.4mm
C129414
10uF
C12
1
SMD,D4xL5.4mm
C72484
Potentiometer
50KΩ
RB1
1
RES-ADJ-TH_3362P
C81264
10KΩ
RB2
1
C118956
Photoresistors
GL5528
RD1
1
RES-TH_L5.1-W4.3-P3.40-D0.5
C125627
Switching diodes
1N4148W
D1~D3
SOD-123
C2099
MOS tubes
SI2301
Q1
1
SOT-23-3
C2891731
DC power outlets
DC-005-25A
DC1
1
DC-IN-TH_DC005
C136715
USB connector
TYPE-C
USB1
1
USB-SMD_KH-TYPE-C-2P
C2919656
TYPE-A
USB2
1
USB-A-TH_USB-302-T
C86461
9
Microcontroller
IAP15F2K61S2
U1
1
LQFP-44
C47451
10
USB chip
CH340C
U2
1
SOP-16
C84681
11
Latch
74HC573PW
U3~U6
TSSOP-20
C5944
12
Darlington transistor array
ULN2003ADR
U7
1
SOIC-16
C7512
13
Timer
NE555
U8
1
SOP-8
C434480
14
Analog-to-digital conversion chip ADC
PCF8591
U9
1
SOIC-16
C8366
15
EEPROM
AT24C02M
U10
1
SOP-8
C356696
16
Temperature sensor
DS18B20
U11
1
TO-92
C376006
17
Decoder
SN74HC138PWR
U12
1
TSSOP-16
C157527
18
NOR
SN74HC02DR
U13
1
SOIC-14
C350559
19
LED
Red light
LED1,LED4,L1~L8
10
LED0805
C84256
Green light
LED2
1
C84260
Blue light
LED3
1
C84259
20
DISPLAY
4 position 0.36 "common anode
DS1,DS2
LED-SEG-TH_12P
C132660
21
Keystroke
SMD 6*6mm
RST,SW1~SW4
SW-SMD_4P
C455113
Self-locking 7*7mm
SW2
1
SW-TH_6P-L7.0-W7.0-P2.00
C318863
22
Relays
HK4100F
K1
1
DIP-6
C12072
23
Pin header
1x4P in-line
J1
1
HDR-TH_4P-P2.54
C2691448
1x3P in-line
J2,J7
HDR-TH_3P-P2.54
C49257
1x8P in-line
J3,J4
HDR-TH_8P-P2.54
C706880
1x20P in-line
1
HDR-TH_20P-P2.54
C429964
24
Female header
1x4P in-line
J5
1
HDR-TH_4P-P2.54
C2718488
25
Ultrasound module
HC-SR04
J5
1
HDR-TH_4P-P2.54
26
Studs
M3
M1~M4
M3
C551322
5. PCB design
The size of the board is controlled within 10*10cm, the layout reference is shown in Figure 6, the DC power socket, USB connector and each expansion interface are placed on the edge of the board, the digital tube is placed on the top, and the keys are arranged under the board. Add silk screen printing and LOGO annotations, and place M3 screw holes at the four corners for fixing the support.
Fig.Layout reference view
Provide the following reference suggestions in the wiring: set the power cable to 30mil, make it as bold as possible, and set the signal cable to 10mil width; In the process of wiring, a straight line is preferred, and the place that needs to be turned is mainly an arc bend or an obtuse angle; The wiring is mainly based on the top-level wiring, and those that can't be connected can be switched to the bottom layer for connection; Finally, add teardrops, add silk screen marking of the key function and interface function.
Fig.Trace reference diagram
After the line is completed, the copper is poured, and the GND network can be connected. Silk screen characters follow the principle of top-down and left-to-right. Add silk screen marking instructions for each pin header interface and potentiometer, and add the project name and LOGO annotation in the blank area of the board.
Fig.8Copper pouring and silk screen printing
6. Explanation of the annex
Provide the topic of "The 13th Blue Bridge Cup SCM Design and Development Project National Competition" and the required resource data package, and attach the "Blue Bridge Cup" National Software and Information Technology Professional Talent Competition (Electronics) Training Guide for those who need to learn.
Link:https://oshwhub.com/course-examples/lan-qiao-bei-iap15f2k61s2-dan-pian-ji-kai-fa-ban
13F_MCU_Objective test question .pdf
617
13F_ MCU_Programming Exam .pdf
514
The 13th Blue Bridge Cup Competition electronic resource data package (DP_SCM_2022) .rar
2361
"Blue Bridge Cup" National Software and Information Technology Professionals Competition (Electronics) Training Guide. pdf
1298
