CompletedBigger and brighter snow lights
This is a larger snowflake lamp based on the open source snowflake lamp made by mondraker. The lamp tube has been changed to 38mm length and yellowish white. Please be careful not to buy the wrong one when purchasing.
In the motherboard's project file, there is a flying cable "VBUS Network" at the Type-c interface that is not connected. The network is already connected on the base, so the network flying cable here is not connected;
Notice:
(1) In order to keep the bottom circuits clean and tidy in this design, most of the circuits are placed on the top layer. There are many unreasonable wirings and irregular routings. However, the circuits in this design can work normally, and it is not recommended for novice students. Refer to this design to learn layout and wiring!
(2) When building the board, be sure to choose a yellow circuit board for the motherboard and a white circuit board for the base.
(3) This design uses a 16P Type C interface that is difficult to solder. After soldering, be sure to test it first before powering on. The connection method will be updated later, so interested friends should pay attention.
(4) Project files can be directly exported to Garber files for ordering without changing any content; the text above can be changed by double-clicking. Note that some text contains solder mask.
Designed by PROGER (from OSHWHub)
