recommended
Pro Edition
free
devices or 10W pads
standardized processes
Std Edition
devices or 1000 pads
STD m32-pocket-wifi-wm8960_rev2
Project tags
CC BY-NC 4.0
License: CC BY-NC 4.0
Mode:
Mode
Editors' pick
Editors' pick
Cloned from m32-pocket-wifi-wm8960
  • 69
  • 0
  • 0
Update time: 2024-12-14 09:49:51
Creation time: 2024-11-05 13:28:05
Pocket (smaller) variant of the Morserino32 morse trainer from OE1WKL. Uses a WM8960 audio codec for audio (true sine CW sidetone). Can be used with a Heltec Wifi v3 or LoRa v3 module (solder jumpers on the backside default to the WiFi module). Project is ongoing, this revision will be tested in the upcoming weeks. More details can be found on the morserino mailing list ("Future hardware" thread).
1 JUMPER 3 JP1,JP2 JUMPER:SOLDERJUMPER-3_P1.3MM_BRIDGED12_PAD1.0X1.5MM COPY2 2
2 TP L/R HEADER-1X2-2.54MM 1
3 PJ-342CB-TG-SMT CN1,CN2,CN3 AUDIO-SMD_PJ-342CB-TS-SMT 3 C2885048
4 SPKR CON SPK HEADER-1X2-2.54MM 1
5 HX 1.25-2PIN WSTP U6 CONN-SMD_2P-P1.25-MX1.25-2P-LT-1 1 C19270000
6 1028 BT1 BAT-TH_KEYSTONE-1028 1 C238063
7 Tactile Momentary 6MM SW3 TACTILE MOMENTARY 6MM TH 1 C23873
8 MSK12D18G2 125 U10 SW-TH_MSK12D18G2 1 C19192981
9 KH-2.54FH-1X18P-H8.5 U5,U7 HDR-TH_18P-P2.54-V-F 2 C2905422
10 1uF C6 C0402 1 C7393850
11 0.1uF C15,C8,C11,C12 C0402 4 C7393850
12 24MHz X1 OSC-SMD_4P-L3.2-W2.5-BL 1 C655082
13 4.7uF C9,C10,C13,C14 C0402 4 C7393850
14 100uF C5,C4 C0402 2 C559125
15 100nF C2,C1 C0402 2 C155422
16 10nF C3 C0402 1 C2840480
17 33k R2 R0402 1 C416388
18 10k R3 R0402 1 C5119777
19 2k2 R4,R5 R0402 2 C328314
20 680 R1 R0402 1 C176113
21 FS-1540 SPK1 BUZ-SMD_5P-L15.0-W15.0-P13.7-BL 1 C482341
22 WM8960CGEFL/RV U1 QFN-32_L5.0-W5.0-P0.50-TL-EP 1 C18752
23 Rotary Encoder SW1 ROTARYENCODER 1 C143790
24 TLP175A(TPL,E U4 SMD-4_L3.7-W4.6-P2.54-LS7.0-BL 1 C141522
25 009159006551906 U2,U3 CONN-SMD_009159006551906 2 C597784
1
1
