Morserino32 Pocket Variant
STDMorserino32 Pocket Variant
1.2k
Creation time:2024-07-29 16:49:41Update time:2024-09-03 23:06:49
Stripped down variant of the Morserino32 open source morse code trainer. Uses a PCM5102 board for I2S audio sidetone. Also requires a heltec lora v3 esp32. Adjusted code can be found here in the "minipcb" branch: https://github.com/haklein/Morserino-32.git
STL for the case are attached. Development is onging, the next revision PCB will also have a speaker connector and will use the adafruit MAX98357a break out board. Stay tuned.
m32-minipcb-case-better-Case_topFillet006.stl
m32-minipcb-case-better-Case_bottom001.stl
Rotary_Knob.stl
