fallout holotape
STDfallout holotape
Creation time:2021-01-04 01:56:31Update time:2022-05-13 17:50:19
circuit for fallout style holotape.
powered via wireless charge coil.
data transmitted via a data send diode and two data receiver light receiver diodes.
data requests are getting send from a terminal to the device with a simple and robust protocol, processed on the micro controller and then passed through to the memory chip.
it is designed to use a 16mbit (2m*8) spi flash ic, larger memory chips could be used after code modifications
