PCB“TEMT6000 Light Sensor – Low-cost Ambient Light Detector for Your Arduino & IoT Projects”
2025-11-26 02:51:32
Agar aap apni DIY electronics, Arduino, ya IoT projects ke liye ek sasta aur reliable light sensor dhund rahe hain — toh TEMT6000 light sensor aapke liye ek best choice hai. Ye sensor environmental light intensity ko accurately measure karta hai aur use analog voltage me convert kar deta hai, jise aap microcontroller (jaise Arduino) ke analog input pin se read kar sakte hain.
TEMT6000 – Features aur Specifications
Visible‑light detection: TEMT6000 ki sensitivity 570 nm peak pe hai, jo ke human eye ke andar aane wale visible light spectrum se milti hai.
Wide spectral range: 440 nm se 800 nm tak — matlab dim se le kar bright light tak efficiently detect karta hai.
Analog output: Light intensity ke hisaab se analog voltage output deta hai (0‑5 V, agar Vcc = 5V ho).
Compatible supply voltage: 3.3V se 5 V — jo isse popular microcontrollers jaise Arduino, ESP, etc. ke saath use karne layak banaata hai.
Operating range: Typically 1 – 1000 Lux (ya environment ki light intensity ke hisaab se) detect kar sakta hai.
Fast response & low power: Phototransistor-based sensor hone ki wajah se, ye light changes pe quickly react karta hai, aur power consumption bhi kam hoti hai.
Common Uses / Applications
Automatic backlight control: Smartphone, tablet, laptop screens ya displays me — ambient light ke hisaab se backlight dim ya brighten karna.
Smart lighting / IoT: Room ya environment me light intensity monitor karke smart lighting systems ya automatic light-on/off controllers banana.
Arduino / Microcontroller Projects: Light meter, automatic night/day switch, light-based alarms ya sensors — simple analog wiring ke saath.
Environmental sensing: Agriculture setups, greenhouses ya indoor farming jahan light levels monitor karna ho.
Popular Posts
More
