PCBUSB-C connector slot region with DRC errors
2025-05-26 14:56:38
Hi
I have added a USB-C plug (LCSC C7421446). It seems to be a version sunk into the PCB, so I had to create a hole for it. I have made a slot region rectangle, slightly larger than the connector. Looking at the 3D render, it looks good, but in the PCB view, there are errors all around. Each SMD pad gives an error, plus the copper regions give errors. How do I install this connector correctly?
thank you
