SchematicTrouble finding proper schematic part (with proper footprint)
2025-01-30 21:09:49
Hi there!
Im an sporadic EasyEDA user, there are sometimes years between uses, as it is primary for personal projects.
In general I understand the metodology from SCH creation thru PCB ordering via gerber files and I've requested plenty of them, mostly some years ago.
Lately every time I need to design a quick circuit, I also struggle to find the proper part. And sometimes I find what looks like what I want and then when I turn into PCB design I find out that the footprint is not what I expected.
I don't usually deal with rare components. Sometime I don't even find the usual 1/4 TH resistors...
Do you guys find it one time and them write down the full description?
Also I get the tab for LCSC Electronics Parts, and EasyEDA parts, which one to use?
Parts I've had issues finding lately
  • Common 1/w TH resistor
  • 1X?? female dupont header, vertical, like the one you would plug an arduino board onto
  • 1X?? line of pads, with no component, spacing 2.54, just to leave for spare connections
  • Small like 10x10mm push button like the ones in the car remotes, with long extension, TH
Sorry to ask for this here but I can't find these all!! I must be doing something wrong... please share your procedure to find parts if possible...
Thanks in advance!
