PCB3D model rendering broken in EasyEDA Pro
2024-10-17 20:08:10
I am using EasyEDA Pro V2.2.32 (Full Online mode) and am having an issue with parts rendering in the 3D viewer.
The parts start to render but as soon as it tries to process a component without a 3D model, it halts rendering of all other 3D models afterwards. Normally ~95% of models show up properly but now only the first 5 models are showing then it errors out on the nonexistent model and doesn't show the remaining ~30 components.
Here is a screenshot of the error and part of the PCB as an example. In the example, CN1 and CN2 are the same exact part # and should both render fine. The issue is CN1 renders after U2 and since U2 errors out, CN1 never renders... I attempted this on Desktop app and also on pro.easyeda.com online version.
Error:
Component causing error: SD card slot, U2:
